18
I frequently use the compose key to type special characters. I now have a fresh install of Ubuntu 14.04, and in the keyboard settings it says "compose key: disabled". I can't find how to set the compose key.
Christine
  • 481
5 Answers5
40
In keyboard settings -> Shortcuts -> Typing -> Compose Key
Click the 'Disabled' across from Compose Key and select the key you want.
LovesTha
  • 505
  • 14
You will need to install dconf Editor from the Ubuntu Software Centre so it will appear in your applications.
If you use an applications list it appears under Sundry or if not in your Activities Overview (type dconf in the ~type to search~ box).
There are other ways of achieving your aim but this is a simple gui method not needing terminal skills.
$ dconf write /org/gnome/desktop/input-sources/xkb-options "['compose:{key}']"
where {key} is your chosen key-name (e.g. "['compose:ralt']" would make right alt your compose key.
From Ubuntu 14.04
Sundry → dconf → org → gnome → desktop → input-sources → xkboptions
e.g. to set the Alt Gr key as compose:
['compose:ralt']
Seth
  • 59,332
cpmman
When you start the dconf editor, select the down pointing triangles in this order: org, desktop, input-sources all within the left pane. Each of these expands a menu where you can select the next option. After you pick input-sources, you will see the xkboptions in the right panel, select that and you can enter your choice as outlined above.
Just click on the "disabled" and choose any of the available keys in the appeared drop-down list. Than you can hit the key and type key combinations. For example
<Key> o / gives ø symbol.
<Key> . . gives … symbol
<Key> a ' gives à
and so one
