In Ubuntu 12.04 on switching on the printer the system automatically recognized the plug in but in Ubuntu 14.04 this would not happen.
I wish someone would show me the method by which I can install HP Laserjet 1020 plus driver and plugin easily.
Here is the way how OP has solved his problem in this comment,
Change directory to Downloads where the hplip will be downloaded. Write in a terminal,
cd ~/Downloads
Download hplip-3.13.11.run from the terminal using wget as,
wget -c http://kaz.dl.sourceforge.net/project/hplip/hplip/3.13.11/hplip-3.13.11.run%22
Note: Newer version of hplip is available. you can check sourceforge.net
Run the package as superuser. You may need to use the package name that you downloaded. Here,
sudo sh hplip-3.13.11.run
Install hplip-gui using apt from the terminal as,
sudo apt-get install hplip-gui
I followed steps given in the blog https://blog.hostonnet.com/how-to-install-hp-laser-jet-1020-plus printer. These are on terminal enter following steps.
sudo apt update
sudo apt remove hplip cups-filters cups hplip-data system-config-printer-udev
sudo apt install build-essential tix groff dc cups
sudo apt install cups-filters unp system-config-printer-gnome
sudo rm -rf /usr/share/hplip
cd /tmp
rm foo*
wget -c http://foo2zjs.rkkda.com/foo2zjs.tar.gz
unp foo2zjs.tar.gz
cd foo2zjs/
make
./getweb 1020
sudo make install
sudo make install-hotplug
Unplug and replug USB printer.
Type system-config-printer, select foo2zjs as the printer driver.
Errors can be checked by entering tail /var/log/syslog
