I have an Asus laptop with a nVidia card. lspci tells me:
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce 610M] (rev a1)
I did a fresh install of Ubuntu 14.04 LTS (64-bit edition).
By default, Ubuntu 14.04 uses the nouveau drivers, but they don't work very well (blinking cursor, slow 3D display, etc.), so I would like to install the proprietary nvidia drivers.
I go in System Settings > Software & Updates > Additional Drivers. Ubuntu proposes me the following options:
Whatever I try to select (other than Nouveau), after I click on "APply Changes", it reverts to Nouveau without any additional feedback...
So I tried to install the drivers manually with apt:
$ sudo apt-get install nvidia-331
Reading package lists... Done
Building dependency tree
nvidia-331 : Depends: lib32gcc1 but it is not going to be installed
Depends: libc6-i386 but it is not going to be installed
If I try to manually install the packages mentioned, I get this error:
$ sudo apt install lib32gcc1 libc6-i386
libc6-i386 : Depends: libc6 (= 2.19-0ubuntu5) but 2.19-0ubuntu6 is to be installed
What can I do to fix this?
Also, do you think it's a bug? (if so I will raise it in Launchpad)
Thanks in advance!
