34
In xubuntu, my desktop icons have dissapeared. I can not remember the cause, but if I do, I will edit this and put it here. Also, when I try to right click on the desktop, nothing happens. I have tried many reboots, but nothing worked. If I have to reset what was on my desktop, that is fine, because all that was on it was some shortcuts to some files.
EDIT: I can view my desktop files from the file manager, if that helps.
guntbert
  • 13,475
lobuo
  • 513
6 Answers6
49
Answered by OP in comments:
navigate to ~/.cache/sessions/
delete any xfce*session directories
run xfdesktop (as your normal user, not root)
logout and log in again
nemo
  • 111
I was having the same problem; xfdesktop (the XFCE desktop manager) should start up automatically, but from one day to another, it stopped doing so.
Symptoms: no wallpaper, no desktop icons, no desktop context menu, no response to Alt+F2.
The problem spontaneously disappeared after taking the following steps. Step 1 is probably sufficient, but since I can no longer reproduce the problem, there is no way of knowing for sure.
  1. rm -R ~/.cache/sessions/* (shell command) as suggested here
  2. log out and log in again (without rebooting in between); based on this post
Since cleaning the session cache is also suggested here, I suppose the problem may have been triggered by a repository update of XFCE.
This command worked for me:
xfdesktop --replace
#!/bin/sh
rm -dvRf /home/nl/.cache/sessions/*
xfdesktop --reload
A bash file placed in "/home/user/" will make running this, if your problem repeats, stupid easy.
Next time it happens: ctr+alt+t and type "bash -insert what name you gave it- " press enter, and your done.
Also if this is one too many steps for your future self you can make a .desktop that will run the bash. One click, and your problem will go away.
copy this into a .txt file and save it as -insert what name you gave it- .desktop should look like "fix.desktop" while you're saving.
#!/usr/bin/env xdg-open
[Desktop Entry]
Name=-insert what name you gave it-
Comment=fix your desktop
Exec=bash -insert what name you gave it-
Icon=/usr/share/icons/-whatever you like for its icon-
Terminal=true
Type=bash
Categories=System
AND if that one click is STILL to much for future you, once you have the .desktop file you can open your start up applications and add it to the list of applications that start when you login, causing it to run every time you log in, and preventing you from ever needing to deal with this again...
Try:
xfdesktop --reload
If that doesn't work, log out and log back in. If that doesn't work, open Settings Manager > Desktop and check the Icons tab and make sure 'Icon type' is set to 'File/launcher icons'.
Ubuntu 20.04.4 LTS my problem was expermenting with "desktop settings" ... submenu => "icons" there is "Appearance - icon types - I selected "none" and correct is "File/Launcher icons"
user
