I recently bought a new laptop, and I am trying to dual boot my system with windows 8.1 and ubuntu. My installer doesn't recognize the windows 8 partition on my hard drive, so it doesn't give me the option to install alongside windows. I can see a large partition that is supposed to be my windows partition in the installer, but it doesn't recognize that it is windows. I have turned off secure boot and fast start-up, but there is no difference. I am thinking about manually partitioning my hard drive in the Ubuntu installer. I have two questions:
First, I am planning on partitioning it with 16 GB swap, which is the amount of ram on my laptop, and about 20 GB for a '/' root logical partition. Is this a good setup for the installer?
My second question is about the grub menu. If I do the manual install, will grub recognize my windows partition even though the ubuntu installer doesn't? Meaning when I see the grub menu, will it just list /dev/sd# or will it say Windows like before, or maybe not even show it at all?
Laptop specs:
HP Envy 15t-j100
Intel i7-4700MQ
16GB RAM
1TB HDD
Charo
  • 3,681
I say that 8 GB of swap would be enough.
I recommend reading this post: askubuntu.com/questions/49109/i-have-16gb-ram-do-i-need-32gb-swap.
Yes, GRUB will recognize a windows partition and add it to the boot menu. If it doesn't you can edit grub and add Windows to it. Read this post.
Cornelius
  • 9,653
The failure to recognize Windows in the installer is a bug in the installer, not a bug in GRUB. In theory, GRUB should detect Windows just fine once you install via the "Something Else" option in the installer. That said, I can't make any promises; GRUB can be pretty finicky about starting Windows on EFI systems, so you might run into some unrelated problem.
Personally, I'd shrink the Windows partition by much more than you're suggesting and set aside more space for a shared-data partition. This will minimize the risk of accessing the Windows partition from Linux (since you won't need to do it), while still enabling you to share data between the two OSes.
(Actually, that's a lie; I wouldn't use Windows more than two or three times a year, so I'd give most of my space to Linux. That's another discussion, though....)
Rod Smith
  • 45,120
  • 66
  • 108
