Since upgrading to 11.10 I can't upgrade any further (trying to get my web server to latest version.) I'm aware of How do I resolve unmet dependencies after adding a PPA? and have tried up to the point of running this:
apt-get remove --dry-run libc6
..but the output is scary and I'm worried about removing this package or at least until I understand what I'm doing better.
Here is the output of apt-get upgrade:
Reading package lists... Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies.
libc-dev-bin : Depends: libc6 (> 2.15) but 2.13-20ubuntu5.3 is installed
libc6 : Depends: libc-bin (= 2.13-20ubuntu5.3) but 2.15-0ubuntu20.2 is installed
libc6-dev : Depends: libc6 (= 2.15-0ubuntu20.2) but 2.13-20ubuntu5.3 is installed
libnih-dbus1 : Depends: libnih1 (= 1.0.3-4ubuntu11) but 1.0.3-4ubuntu2 is installed
E: Unmet dependencies. Try using -f.
Obviously I've done what it says to no avail.
Can anyone suggest a safe way to fix these issues? Ultimately I'm trying to get my web server to the latest version of Ubuntu so maybe there's a way to bypass this. Note that I have command line access only. I've got a few live websites there that are easily backed up but otherwise nothing too critical.
Thanks in advance for any help.
Rob
11.10 is no longer supported since 9 May 2013. Upgrading all the way to 14.04 is a long call.
I suggest you backup your data and install 14.04 from scratch.
To Do
  • 15,833
