27
I upgraded from 13.10 to 14.04 and now the nm-applet no longer shows in the system tray. I already tried purging and reinstalling the network-manager-gnome package but that didn't help. When I run nm-applet manually in the terminal I get the following output:
** (nm-applet:7419): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-gBrnqcTAVj: Connection refused
I tried multiple system trays: i3bar (my default), trayer and the xfce4-panel. Other tray apps work in all three of them (like dropbox). The network manager itself works, as it connects to known networks and outputs notifications. Does someone know how to fix this?
bain
  • 12,200
qasfux
  • 371
6 Answers6
22
You could use the indicator plugin instead, but you may see frequent crashes. The crash is caused by the Applications Menus indicator. Add the indicator plugin and, before it crashes, right click on it, choose 'properties' and tick the 'hidden' checkbox next to the 'Application Menus (Global Menu)' indicator. Then restart the panel with 'xfce4-panel -r'
Instead, I fixed nm-applet by changing the 'Exec' line in /etc/xdg/autostart/nm-applet.desktop to 'dbus-launch nm-applet'
Adz
  • 221
It turns out that to see the nm-applet icon, you have to install package "xfce4-indicator-plugin" and add "Indicator Panel" to the panel.
That adds a whole bunch of icons that you probably don't want, and that ignore your theme choice. But at least you'll have the nm-applet icon again. For a while. The indicator-panel dies every few seconds for me, and when it does stay running long enough for me to try configuring it, the configuration panel doesn't work either.
Your mileage may vary - try the "Indicator Panel" and see if it works for you.
I had the same problem, but i just kill 'indicator-application-service' and icons network, bluetooth and skype appear again. I use xfce on amd64.
user278801
  • 1,278
I found the solution to this problem here: http://linuxg.net/how-to-fixrestore-the-missing-network-manager-from-the-unity-top-panel-on-ubuntu-13-04-raring-ringtail-and-ubuntu-12-10-quantal-quetzal/
Quoting their site: The fix for this issue is simple, first stop the network-manager service, like this:
$ sudo /etc/init.d/network-manager stop
Delete the /var/lib/NetworkManager/NetworkManager.state file:
$ sudo rm /var/lib/NetworkManager/NetworkManager.state
Turn back on the network-manager service:
$ sudo /etc/init.d/network-manager start
jkt123
  • 3,600
I have the same issue and came across this solution: http://www.webupd8.org/2014/04/fix-lubuntu-1404-network-manager.html
Hope this helps!
Guest
I blatantly stole the answer from one of the comments to http://www.webupd8.org/2014/04/fix-lubuntu-1404-network-manager.html as Adz linked to and Eric Carvalho suggested be included in an actual answer. So, now we have the answer here in AskUbuntu. This is what I did.
Dimitrios Charalampidis
This fix does not work for everybody... if that's the case for you, too.. then try this: go to menu >Preferences > Default applications for LXSession, select the autostart tab and scroll to find Network. Uncheck it and recheck it, then go to your home folder and press ctrl+h to show hidden files and folders, go to .config/autostart, there you will find a Network.desktop file right click on it and select Leafpad, it is likely that under NotShowIn section it includes LXDE just delete it, save the file and exit, then log out and login again this will fix the issue.
For those that came looking for the actual answer on that website, here it is.
Lubuntu 14.04: fix 1
To fix the Network Manager not showing up on the panel issue, from the Lubuntu menu select Preferences > Default applications for LXSession, then click on the Autostart tab and under "Manual autostarted applications" type "nm-applet", then click the "+ Add" button on the left:
Now log out, log back in and you should see the Network Manager icon on the panel:
fix somewhat via lffl.org
Lubuntu 14.04 / Xubuntu 14.04: fix 2
If the above solution didn't work for you in Lubuntu 14.04 or if you're using Xubuntu 14.04 and you're having this issue, here's another solution. Basically, the solution below is for those who must run "nm-applet" as root to get it to show up in the pane - we'll be using dbus-launch to launch nm-applet at startup.
To get the Network Manager applet to work properly in either Lubuntu 14.04 or Xubuntu 14.04, run the following command: sudo sed -i 's/Exec=nm-applet/Exec=dbus-launch nm-applet/' /etc/xdg/autostart/nm-applet.desktop The command above replaces "nm-applet" with "dbus-launch nm-applet" in the nm-applet autostart desktop file.
UPDATED Ok, I also followed the advice from here: http://www.bauer-power.net/2014/05/permanent-fix-for-missing-network.html
What you need to do is edit /etc/xdg/autostart/nm-applet.desktop with your favorite text editor. I like nano, so I ran the following from the terminal: sudo nano /etc/xdg/autostart/nm-applet.desktop Go down to the Exec line and change the entry from nm-applet to dbus-launch nm-applet. Save the file and reboot!
