How can I setup audio in Ubuntu on the Apple MacBook 2,1?
The laptop has three speakers which don't appear correctly on 12.04.
popey
  • 24,549
The MacBook 2,1 has a 2.1 audio speakers (Left & Right speakers, and a Base). By default the speakers are not setup properly, so the audio unbalanced. This guide will help setup a new audio profile for the speakers so the audio will sound properly.
Edit ALSA cofig file and add the new profile
sudo gedit /usr/share/pulseaudio/alsa-mixer/profile-sets/extra-hdmi.conf
Find the following code in the config file
[Mapping analog-stereo]
device-strings = front:%f hw:%f
<omitted code>
priority = 10
Add the following section after the code above
[Mapping analog-surround-21]
device-strings = surround40:%f
channel-map = front-left,front-right,lfe,lfe
paths-output = analog-output analog-output-speaker analog-output-desktop-speaker
priority = 7
direction = output
Restart the audio (the first part kills pulseaudio, the second reloads ALSA)
pulseaudio -k && sudo alsa force-reload
Next you need to switch to the 2.1 audio profile, you can do this by clicking on the audio indicator in the top right, then “Sound Settings...”. In the new window look for “Mode:” setting and click on the dropdown, then click on “Analog Surround 2.1 Output”.
BvL
  • 46
Also, as shown on subwoofer sound preferences problem
edit /etc/pulse/daemon.conf and,
find ";enable-lfe-remixing: no" change "no" to "yes" and, uncomment (remove the ";" form the beginning of the line).
