Yes, it is possible to boot Windows 8 in UEFI mode, even if you installed it on a legacy partitioned disk (MS-DOS/MBR). Of course you would need a UEFI compatible GRUB installation on another GPT partitioned disk.
In Windows, install a new boot configuration to volume C: by running the following command:
bcdboot C:\Windows /s C: /f uefi
When booted in UEFI mode this will not only create a new boot configuration in C:\EFI\ but also register a new UEFI bootloader in NVRAM. You can remove the entry later with efibootmgr in Ubuntu (for instructions see: How do I remove "Ubuntu" in the bios boot menu? (UEFI)).
Of course you can also choose another location, but this method should be the easiest. For more details on bcdboot see the corresponding Microsoft Technet article.
In Ubuntu, add a custom GRUB menu entry by adding the following lines to /etc/grub.d/40_custom:
menuentry "Windows 8 (BCD-UEFI configuration on system drive /dev/sda2)" --class windows --class os {
insmod part_msdos
insmod ntfs
insmod search_fs_uuid
insmod chain
set root='hd0,msdos2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 2ACC7043CC700B79
else
search --no-floppy --fs-uuid --set=root 2ACC7043CC700B79
fi
chainloader /EFI/Microsoft/Boot/bootmgfw.efi
Note that you will need to edit the following parameters if your configuration differs:
- This entry is configured to boot from the 2nd partition (
msdos2) of the 1st hard drive (hd0 or ahci0).
- You also need to replace the filesystem UUID (
2ACC7043CC700B79) with yours. In this example you could run sudo blkid /dev/sda2 to get the UUID or start GParted.
- Reminder: This example deals with a drive that has a legacy partition table. If yours is GPT, then replace
msdos with gpt.
Finally run sudo update-grub to generate the new configuration.
Answer moved from https://askubuntu.com/q/377807/40581 as it looked out of place there.
