I'm using Xubuntu 14.04, 64 bit
The output of xfce4-about is
xfce4-about-Message: No vendor information found in "/usr/share/xfce4/vendorinfo
However I believe I'm using 4.12 but...
Anyway, Everything was working fine, until I had an issue, and had to do sudo apt-get install xubuntu-desktop
Just to be sure that I'm using the latest version that comes with 14.04, and not the official version that comes with 13.10, I upgraded it
$ sudo add-apt-repository ppa:xubuntu-dev/xfce-4.10
$ sudo add-apt-repository ppa:xubuntu-dev/xfce-4.12
$ sudo apt-get update
$ sudo apt-get dist-upgrade
All is fine till today, the top panel is a mess, too many indicators
I can't remove the bluetooth indicator on the left. I can't move any indicator, if I remove any indicator from the panel, the whole panel will be gone.
I tried resetting xfce but does not seem to fix it.
The output of xfce4-panel is
xfce4-panel
init: indicator-messages main process ended, respawning
init: indicator-bluetooth main process ended, respawning
init: indicator-power main process ended, respawning
init: indicator-datetime main process ended, respawning
init: indicator-application main process ended, respawning
init: indicator-sound main process ended, respawning
init: indicator-messages respawning too fast, stopped
init: indicator-application respawning too fast, stopped
init: indicator-datetime respawning too fast, stopped
init: indicator-sound respawning too fast, stopped
init: indicator-power respawning too fast, stopped
init: indicator-bluetooth respawning too fast, stopped
