12
I have a very long document containing lots of svg images created using the extension TexMaths. This extension uses the latex installation to create svg image of the inputted equation (or set of equations). The latex code for each equation (or set of equations) is embedded in the image as part of its Description. Such a Description can be accessed by right clicking the svg image and choosing the option Description.
I want to replace all the svg images using a suitable macro, by the embedded descriptions.
e.g. from
The Einstein's famous equation, [svg embedded equation : E = mc 2], tells us that mass can be converted to energy and vice-versa.
To
The Einstein's famous equation, E = mc^2, tells us that mass can be converted to energy and vice-versa.
This will allow me to convert by hand the odt file containing numerous TexMaths equations to LaTeX.
user30131
  • 121
This is a different way without using Macros. As .odt file is basically just zipped files and the main file is an XML.
  1. Create a XML style sheet texmath_raw_equation.xslt
    Full Contents are here, just in case link brakes.
    <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:office="urn:oasis:names:tc:opendocument:xmlns:office:1.0" xmlns:style="urn:oasis:names:tc:opendocument:xmlns:style:1.0" xmlns:text="urn:oasis:names:tc:opendocument:xmlns:text:1.0" xmlns:table="urn:oasis:names:tc:opendocument:xmlns:table:1.0" xmlns:draw="urn:oasis:names:tc:opendocument:xmlns:drawing:1.0" xmlns:fo="urn:oasis:names:tc:opendocument:xmlns:xsl-fo-compatible:1.0" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:meta="urn:oasis:names:tc:opendocument:xmlns:meta:1.0" xmlns:number="urn:oasis:names:tc:opendocument:xmlns:datastyle:1.0" xmlns:svg="urn:oasis:names:tc:opendocument:xmlns:svg-compatible:1.0" xmlns:chart="urn:oasis:names:tc:opendocument:xmlns:chart:1.0" xmlns:dr3d="urn:oasis:names:tc:opendocument:xmlns:dr3d:1.0" xmlns:math="http://www.w3.org/1998/Math/MathML" xmlns:form="urn:oasis:names:tc:opendocument:xmlns:form:1.0" xmlns:script="urn:oasis:names:tc:opendocument:xmlns:script:1.0" xmlns:ooo="http://openoffice.org/2004/office" xmlns:ooow="http://openoffice.org/2004/writer" xmlns:oooc="http://openoffice.org/2004/calc" xmlns:dom="http://www.w3.org/2001/xml-events" xmlns:xforms="http://www.w3.org/2002/xforms" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:rpt="http://openoffice.org/2005/report" xmlns:of="urn:oasis:names:tc:opendocument:xmlns:of:1.2" xmlns:xhtml="http://www.w3.org/1999/xhtml" xmlns:grddl="http://www.w3.org/2003/g/data-view#" xmlns:officeooo="http://openoffice.org/2009/office" xmlns:tableooo="http://openoffice.org/2009/table" xmlns:drawooo="http://openoffice.org/2010/draw" xmlns:calcext="urn:org:documentfoundation:names:experimental:calc:xmlns:calcext:1.0" xmlns:loext="urn:org:documentfoundation:names:experimental:office:xmlns:loext:1.0" xmlns:field="urn:openoffice:names:experimental:ooo-ms-interop:xmlns:field:1.0" xmlns:formx="urn:openoffice:names:experimental:ooxml-odf-interop:xmlns:form:1.0" xmlns:css3t="http://www.w3.org/TR/css3-text/" version="1.0">
        <xsl:template match="@* | node()">
          <xsl:copy>
            <xsl:apply-templates select="@* | node()"/>
          </xsl:copy>
        </xsl:template>
        <xsl:template match="draw:g">
            <xsl:value-of select="svg:desc"/>
        </xsl:template>
    </xsl:stylesheet>
  2. Extract .odt file to tmp folder, example texmath_test.odt:
    7z x -otmp texmath_test.odt
  3. Replace TexMath image (hold by <draw:g></draw:g> tag) with its description (hold by <svg:desc></svg:desc> tag)
    xsltproc -o content.xml texmath_raw_equation.xslt tmp/content.xml
    mv content.xml tmp/content.xml
  4. Compress back to new .odt file
    cd tmp
    7z a -tzip ../texmath_test_new.odt *
    cd ..
    rm -r tmp
References:
user.dz
  • 49,176
