Before i start, i've tried the solution from this thread
How do I remove a malformed line from my sources.list?
but unfortunately, the steps performed in that thread are already covered for me. The error I'm getting is:
Malformed line 3 in source list /etc/apt/sources.list.d/cloudarchive-havana.list (dist)
E: The list of sources could not be read.
I'm not too sure what is causing this but it won't allow me to use the ubuntu software center or perform any updates.
Here is the output from the malformed directory:
deb http://ubuntu-cloud.archive.canonical.com/ubuntu precise-updates/havana main
deb-src http://ubuntu-cloud.archive.canonical.com/ubuntu precise-updates/havana main
deb http://docs.openstack.org/havana/install-guide/install/apt/content/basics-packages.html
Can anyone point me in the direction of a solution please?
Why is there a html page in your sources?
This does not belong in sources.list since it is not of a normal format.
Compare it to the other 2 and you will see the sources.list needs 4 sections and there are only 2 on this like. It is missing precise-updates/havana and main
Rinzwind
  • 309,379
The last line doesn't look right, I've never seen a ppa source ending as "something.html" so you could try commenting it and leaving the file like this:
#deb http://docs.openstack.org/havana/install-guide/install/apt/content/basics-packages.html
To edit the file, open a terminal and type this:
gksu gedit /etc/apt/sources.list.d/cloudarchive-havana.list
Then, try to run an update again.
