I read that it has better GTK+ integration,is faster and java has been minimized . so i wanted to try it . How do i install it ? A PPA would be preferable.
Lincity
  • 25,749
LibreOffice 3.4.3 for Natty was released 7 Oct 2011.
The standard LibreOffice ppa should be used to update - see linked question on how to install.
For those that like to live on the bleeding edge, there are .deb files you can download directly from the LibreOffice website here. Obviously, these will be vanilla LibreOffice and therefore probably will not include any stuff the ubuntu packagers also add.
Linked Question:
  1. Will LibreOffice 3.4 be included in an update?
fossfreedom
  • 174,526
Visit the PPA's overview page in Launchpad. click this link https://launchpad.net/~libreoffice/+archive/ppa
Step 2: Use the Display sources.list entries drop-down box to select the version of Ubuntu you're using.
Step 3: You'll see that the text-box directly below reads something like this:
deb http://ppa.launchpad.net/libreoffice/ppa/ubuntu YOUR_UBUNTU_VERSION_HERE main deb-src http://ppa.launchpad.net/libreoffice/ppa/ubuntu YOUR_UBUNTU_VERSION_HERE main
Copy those lines.
Step 4: Open a terminal and type:
sudo nano /etc/apt/sources.list
This will open a text editor containing the list of archives that your system is currently using. Scroll to the bottom of the file and paste the lines you copied in the step above.
Save the file and exit the text editor.
Step 5: Back on the PPA's overview page, look for the Signing key heading. You'll see something like:
1024R/72D340A3
Copy the portion after the slash but not including the help link; e.g. just 72D340A3.
Step 6: Now you need to add that key to your system so Ubuntu can verify the packages from the PPA. In your terminal, enter:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 72D340A3
Replace 72D340A3 with whatever you copied in the step 5.
This will now pull down the PPA's key and add it to your system.
Step 7: Now, as a one-off, you should tell your system to pull down the latest list of software from each archive it knows about, including the PPA you just added:
sudo aptitude update
sudo aptitude install libreoffice
Now you're ready to start libreoffice
dsaint
  • 774
Follow this instructions --you have to download DEB packages until they update the official PPA.
http://www.unixmen.com/software/1755-libreoffice-340-is-released-installation-instructions-for-ubuntu-fedora-debian
fitojb
  • 2,233
