I know there is a find switch. but I want to know how to search a specific type of file. For example I need kind of terminal command which search for only executable files.
Asked
Active
Viewed 1.6k times
14
This should do what you want:
find . -perm -u+x -type f
If you want to find everything that could possibly be executable, you could look at mime-types or file output. That would be counter-productive though since you couldn't possibly catch every script.
References:
The man page
Stackoverflow
RobotHumans
- 30,112
11
This also works,
find ~ -type f -executable
List all executable files inside your /home/$USER directory.
From man find
-executable
Matches files which are executable and directories which are
searchable (in a file name resolution sense). This takes into
account access control lists and other permissions artefacts
which the -perm test ignores. This test makes use of the
access(2) system call, and so can be fooled by NFS servers which
do UID mapping (or root-squashing), since many systems implement
access(2) in the client's kernel and so cannot make use of the
UID mapping information held on the server. Because this test
is based only on the result of the access(2) system call, there
is no guarantee that a file for which this test succeeds can
actually be executed.
Avinash Raj
- 80,446
