I am trying to export to a file the size of only the executable files in my directory (which doesn't ends with .sh).
This is the command I made, which, it seems, export non-executable as well as executable files:
file -x -type  | size * > /home/user/Desktop/userbinfiles.xls
What I want to achieve, if it's possible, is that kind of file exported:
A file with:
  1. size of the file
  2. type of the file
  3. file name
I understand my command doesn't do that.
And Ideas?
Yaron
  • 13,453
Alan
  • 111
You can use the following command to execute size on all execute-ables files:
find . -executable -type f | xargs size
  • The find command will find all execute-ables files under the current directory
  • xargs will send the result list of files to be processed by the size command
You can use the following command to execute size on all execute-ables files which doesn't ends with .sh:
find . -executable -type f  | grep -v '\.sh$' |  xargs size
  • The command grep -v '\.sh$' will remove all files ends with .sh from the list
Yaron
  • 13,453
