18
When I copy/paste from a website into gnumeric (or LibreOffice Calc) from a website, I want to be able to quickly strip away all hyperlinks and leave just text.
How do I do this?
Solutions in either program will be accepted, although gnumeric is preferred.
David Oneill
  • 12,614
5 Answers5
30
In LibreOffice Calc (Version: 4.1.3.2; Build ID: 410m0(Build:2):
  • select the cells containing hyperlinks
  • Click on Format > Clear Direct Formatting (or just press Ctrl+M)
That's all.
DK Bose
  • 44,553
In Gnuneric: Menu "Edit" -> "Clear..." -> "Formats and Hyperlinks":
Another way is selecting the cells to edit, right-click and select "Remove [n] Hyperlinks".
tohuwawohu
  • 7,502
When you copy the info, and you're ready to paste, click on Edit --> Paste Special --> Unformattted text, and once the new window opens, review the info,choose your text import settings, and then click OK. See images below.
The text example in the last image, are links from a website, and it got pasted as text, and not hyperlinks.
Mitch
  • 109,787
In LibreOffice Calc (Version: 4.3.7.2; Build ID: 4.3.7.2-2.el6_9.2):
  1. Click Edit => Links...
  2. Click 'Break Link' and 'Yes' on every line item
  3. Click Close
Everlight
  • 111
In LibreOffice Calc, Go to the menu Header on top-->from the dropdown selection of paste button select unformatted text and you're done!
