SOLVED. Edited: see below.
I think I've scoured the internet long enough for this issue. It has been asked many times, but none of the solutions work for me. I upgraded to BlueZ 5 because I want to be able to use its low energy capabilities eventually. Right now, though, I can't get even get my devices paired. I can't use a GUI because this will eventually be for an embedded linux system. Therefore, I think I also can't use bluetoothctl, because it requires an interactive session. (I may be wrong on that.) So I want everything to be either through BASH, C, or python, in that order. Also, because it needs to be automated, the pairing and connection will have to be initiated from the bluetooth device, not from the linux box. Lastly, all devices need to use the a2dp profile.
There seem to be many approaches, but I am not clear on where one ends and the other begins:
APPROACH 1:
a)$ sudo bluetoothd -d -n #runs bluetoothd in verbose mode
b)$ hciconfig hci1 up #turns the device on
$ hciconfig -a #see device properties
Type: BR/EDR Bus: USB
BD Address: 00:02:72:C5:D8:E0 ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN ISCAN
RX bytes:32875 acl:761 sco:0 events:1037 errors:0
TX bytes:20178 acl:780 sco:0 commands:329 errors:0
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Link mode: SLAVE ACCEPT
Class: 0x00010c
Service Classes: Unspecified
Device Class: Computer, Laptop
HCI Version: 4.0 (0x6) Revision: 0x1000
LMP Version: 4.0 (0x6) Subversion: 0x220e
Manufacturer: Broadcom Corporation (15)
c) try to pair from the device.
Result: from bluetoothd:
bluetoothd[5359]: src/adapter.c:connected_callback() hci1 device 70:72:3C:62:49:7F connected eir_len 15
bluetoothd[5359]: src/adapter.c:user_confirm_request_callback() hci1 70:72:3C:62:49:7F confirm_hint 1
bluetoothd[5359]: src/device.c:new_auth() Requesting agent authentication for 70:72:3C:62:49:7F
** bluetoothd[5359]: No agent available for request type 2
** bluetoothd[5359]: device_confirm_passkey: Operation not permitted
bluetoothd[5359]: src/adapter.c:btd_adapter_confirm_reply() hci1 addr 70:72:3C:62:49:7F success 0
bluetoothd[5359]: src/adapter.c:bonding_attempt_complete() hci1 bdaddr 70:72:3C:62:49:7F type 0 status 0x5
bluetoothd[5359]: src/device.c:device_bonding_complete() bonding (nil) status 0x05
bluetoothd[5359]: src/device.c:device_bonding_failed() status 5
bluetoothd[5359]: src/adapter.c:resume_discovery()
bluetoothd[5359]: src/adapter.c:dev_disconnected() Device 70:72:3C:62:49:7F disconnected, reason 3
bluetoothd[5359]: src/adapter.c:adapter_remove_connection()
bluetoothd[5359]: src/adapter.c:bonding_attempt_complete() hci1 bdaddr 70:72:3C:62:49:7F type 0 status 0xe
bluetoothd[5359]: src/device.c:device_bonding_complete() bonding (nil) status 0x0e
bluetoothd[5359]: src/device.c:device_bonding_failed() status 14
Device says Couldn't pair with Adapter-1 because of an incorrect PIN or passkey.
Based on the starred responses above, I looked into why there wasn't an agent. What's an agent? Who knows, but I inferred that it was the middleman between my device and the bluetooth daemon.
d) $ ../bluey-5.15/test/simple-agent #I also tried using sudo with these commands
or $ ../bluey-5.15/test/simple-agent hci1
This is a python script that handles incoming pairing requests. If successful, it also tries to 'trust' and 'connect'
output: Agent registered
e) then I try again to pair from the device.
simple-agent output:
RequestConfirmation (/org/bluez/hci1/dev_70_72_3C_62_49_7F, 110643)
Confirm passkey (yes/no): yes
I hit pair on the BT device and it says paired, but simple-agent hangs. I have used BlueZ 4, and I am pretty sure it's supposed to say something like "New Device XX_XX_XX_XX_XX_XX"
bluetoothd output:
** bluetoothd[5359]: src/agent.c:set_default_agent() Default agent set to :1.126 /test/agent
bluetoothd[5359]: src/adapter.c:user_confirm_request_callback() hci1 70:72:3C:62:49:7F confirm_hint 0
bluetoothd[5359]: src/agent.c:agent_ref() 0xa59290: ref=2
bluetoothd[5359]: src/agent.c:agent_request_confirmation() Calling Agent.RequestConfirmation: name=:1.126, path=/test/agent, passkey=110643
bluetoothd[5359]: src/agent.c:agent_ref() 0xa59290: ref=3
bluetoothd[5359]: src/adapter.c:btd_adapter_confirm_reply() hci1 addr 70:72:3C:62:49:7F success 1
bluetoothd[5359]: src/agent.c:agent_unref() 0xa59290: ref=2
bluetoothd[5359]: src/agent.c:agent_unref() 0xa59290: ref=1
bluetoothd[5359]: src/adapter.c:new_link_key_callback() hci1 new key for 70:72:3C:62:49:7F type 5 pin_len 0
bluetoothd[5359]: src/device.c:device_set_bonded()
bluetoothd[5359]: src/device.c:device_bonding_complete() bonding (nil) status 0x00
So this does something.
hcidump output:
$ hcidump -i hci1
HCI sniffer - Bluetooth packet analyzer ver 5.15
device: hci1 snap_len: 1500 filter: 0xffffffffffffffff
> HCI Event: Connect Request (0x04) plen 10
bdaddr 70:72:3C:62:49:7F class 0x5a020c type ACL
> HCI Event: Command Status (0x0f) plen 4
Accept Connection Request (0x01|0x0009) status 0x00 ncmd 1
> HCI Event: Connect Complete (0x03) plen 11
status 0x00 handle 11 bdaddr 70:72:3C:62:49:7F type ACL encrypt 0x00
Read Remote Supported Features (0x01|0x001b) status 0x00 ncmd 1
> HCI Event: Read Remote Supported Features (0x0b) plen 11
Read Remote Extended Features (0x01|0x001c) status 0x00 ncmd 1
> HCI Event: Command Complete (0x0e) plen 10
IO Capability Request Reply (0x01|0x002b) ncmd 1
status 0x00 bdaddr 70:72:3C:62:49:7F
> HCI Event: Read Remote Extended Features (0x23) plen 13
status 0x00 handle 11 page 1 max 1
Features: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Remote Name Request (0x01|0x0019) status 0x00 ncmd 1
> HCI Event: Remote Name Req Complete (0x07) plen 255
status 0x00 bdaddr 70:72:3C:62:49:7F name 'Prism II'
User Confirmation Request Reply (0x01|0x002c) ncmd 1
> HCI Event: Disconn Complete (0x05) plen 4
status 0x00 handle 11 reason 0x13
Reason: Remote User Terminated Connection
I even tried bluetoothctl, but it has the same results. The funny thing is that some scripts from BlueZ (like test-device) can see the BT device for some commands, but not others. For instance, test-device will 'trust' the device, but when I try to 'remove' it, it doesn't exist.
APPROACH 2:
DBUS directly using the dbus-send --system commands. I don't think any of these commands will do me any good until I can pair and connect the device.
APPROACH 3:
I tried all of the suggestions on this post. There is no /etc/bluetooth/hcid.conf in BlueZ 5. Do I need to create one? The rfcomm command will connect, but then disconnect right after.
$ sudo rfcomm connect /dev/rfcomm0 70:72:3C:62:49:7F 1
Connected /dev/rfcomm0 to 70:72:3C:62:49:7F on channel 1
Press CTRL-C for hangup
Disconnected
bluetoothd output:
bluetoothd[5359]: src/adapter.c:connected_callback() hci1 device 70:72:3C:62:49:7F connected eir_len 10
hcidump output:
$ hcidump -i hci1
Create Connection (0x01|0x0005) status 0x00 ncmd 1
Authentication Requested (0x01|0x0011) status 0x00 ncmd 1
Link Key Request Reply (0x01|0x000b) ncmd 1
> HCI Event: Auth Complete (0x06) plen 3
Set Connection Encryption (0x01|0x0013) status 0x00 ncmd 1
> HCI Event: Encrypt Change (0x08) plen 4
status 0x00 handle 11 encrypt 0x01
Exit Sniff Mode (0x02|0x0004) status 0x0c ncmd 1
Error: Command Disallowed
Any suggestions? Am I:
Forgetting something really obvious?
Using the tools incorrectly?
Forgetting to set a config file?
Edit:
Since the bluez simple-agent wasn't giving me any useful errors, I wrote my own pairing agent. Once I did, I was able to pair but not connect. bluetoothd gave me this new error:
bluetoothd[3078]: profiles/audio/a2dp.c:a2dp_source_connect() path /org/bluez/hci0/dev_70_72_3C_62_49_7F
bluetoothd[3078]: a2dp-source profile connect failed for 70:72:3C:62:49:7F: Protocol not available
This post pointed out that maybe my LOCAL bluetooth adapter wasn't supporting the a2dp profile of my audio source. (Not acting like a sink) Then I saw that the same issue has been experienced by many people upgrading from BlueZ4 to BlueZ5. The issue also was posted on the BlueZ mailing list.
So far, I haven't found a way to add this protocol to my adapter.
