-1
I want to install Ubuntu alongside Windows 8.1, but I can't do the partitioning because Ubuntu does not recognize Windows 8.1. Everything was OK in Ubuntu, but when I shut down Ubuntu and booted to Windows, it looked like I had changed to "Zoom" because everything on the screen looked too big. I checked the appearance of the screen, and it was set at the default. What can I do to fix this?
karel
  • 122,292
  • 133
  • 301
  • 332
If you have preinstalled Windows 8, your probably have a UEFI Bios system, in which case the safest way to install ubuntu in my opinion is to switch the UEFI to Legacy.
If you already attempted to install Windows 8 without the boot switch step, I would backup my data, repair or recover windows 8 then try install ubuntu after Legacy boot enabled.
If you insist on installing it using the UEFI Bios, you want to look at these steps: Installing Ubuntu Alongside a Pre-Installed Windows with UEFI
Moga
  • 259
