I'm having a serious problem. I use dual OS, so I'm posting with Windows. Somewhat about 2-3 hours before everything was working fine I have modified Ubuntu a lot and was using Mac OS X login screen. It was working fine but I was just having fun and typed this command in terminal to power off (using Ubuntu 13.10) {and using root}.
sudo shutdown -h now
Also I changed the password for su using
sudo passwd root
I kept my laptop aside and came after 2-3 hours. it booted with a splash screen of mac. then it took to a blank screen (OK this happens every time, but after 5-10 seconds login appears), but these times I'm getting a black screen with a mouse. I can move the mouse but can't log in. Only the black screen is there, but everything else is working when I press power button it shuts down like usual.
screenshot
I'm stuck, please help me!
Melebius
  • 11,750
Ukiyo
  • 405
To fix this, follow the steps below:
1- Turn on your computer and wait for it to boot up.
2- Once it boots up, press Ctrl+Alt+F1 to enter terminal
3- Type your username, press enter, and type your password and press enter again.
4- Now type
startx
This should start your desktop. Once here, you can uninstall/reset whatever was causing the problem (in this case Mac OS LightDM theme).
5- Reboot the computer it should boot up normally!
Moose
  • 325
  • 14
Try to run the following command:
sudo apt-get install lightdm --reinstall
and restart, if it works then enjoy.
If it does not work, then you can run following command:
sudo deborphan | sudo xargs apt-get -y remove lightdm --purge && sudo apt-get install lightdm
Aditya
  • 13,616
