I am using Synapse + Unity Dash for searching and it seems that neither of these can index folders I've accessed in my NTFS partition. I believe this is because Zeitgeist does not index folders, and locate (which Synapse uses, I believe) does not touch my NTFS drive.
So in short, is there any way to index my NTFS partition ? In such a way that it is accessible via locate. Or perhaps make Zeitgeist index folders as well?
As of now, Dash gives results from NTFS partition, but there are no folders in the result. On the other hand, locate gives me folders, but only on the native ubuntu partition.
Nemo
  • 9,610
Dash is using the index database created by locate. To make locate to index and show file on an NTFS partition, you should edit the file /etc/updatedb.conf, and change the line
PRUNEPATHS="/tmp /var/spool /media"
to
PRUNEPATHS="/tmp /var/spool"
This works if your NTFS partition is mounted on a mountpoint under /media (highly probable).
To update immediately the locate database, run
sudo updatedb
Bradzzv
  • 107
enzotib
  • 96,093
Zeitgeist logs events by two ways
  1. Zeitgeist Datahub
  2. Selective Datasources
Datahub
The first one is installed by default in Ubuntu (Natty and later) along with Zeitgeist. Datahub is a passive logger which is GtkRecentManager on steroids. Any new entry to ~/.recently-used.xbel is taken up by Datahub and added to Zeitgeist
Datasources are extensions/plugins/addins/addons for applications which help in logging events. Example Tomboy notes are not logged by datahub as they are not logged by GtkRecentManager.
In this case a Tomboy datasources (implemented as a plugin) can be enabled which logs events like Note Open,Closed, Created and Deleted
If you are on Natty, then you install Datasources for these applications
  • Bzr
  • Emacs
  • Eye of Gnome
  • Geany
  • gedit
  • Rhythmbox
  • Tomboy
  • Totem
  • Vim
  • XChat
You can install the datasources by sudo apt-add-repository ppa:zeitgeist/ppa
and look for packages zeitgeist-datasource-* (e.g. zeitgeist-datasource-rhythmbox)
OTOH you can install Banshee's datasource by installing the package banshee-extensions-zeitgeistdataprovider
If you open files, start/stop tracks, open/close/create/delete notes or any relevant activity from these applications then they will be logged. Even the music tracks are logged(their URI on the disk).
There are be two problems
  • GtkRecentManager fails to work on NTFS partition
  • Everytime you mount your NTFS partition, it is assigned a different mount point. (You can pin it in /etc/fstab)
I can guess the problem can be in latter. Can you try installing banshee datasource, enable the datasource, listen to a few tracks(on NTFS partition) and then try to find them via Synapse or Dash (I personally prefer Synapse)
Manish Sinha
  • 11,671
Haver you tried Recoll? Is pretty good but so far still having troubles adding the NTFS partitions, everyone tells me that in settings you can do that, but there is no option to add something beside /home
