I have a Panasonic TH-L50DT60 which supports A2DP audio streaming over Bluetooth. I have a netbook running Ubuntu. I edited my /etc/bluetooth/audio.conf by uncommenting these:
Enable=Source
SCORouting=PCM
AutoConnect=true
I tested whether my laptop receives audio by connecting a Nexus phone. I played a song on the phone and there was audio output from laptop speakers.
After this, I did a Bluetooth scan on the TV to see if it detects my laptop as an audio sink. But it failed to show any devises. But my laptop Bluetooth stack sees the TV as a A2DP audio source. As TV is the audio source and it should detect my laptop as an audio sink and it is not happening. I have many Bluetooth devises and TV detects none. So, how can I get my TV to detect my laptop as an A2DP audio sink?
nixnotwin
  • 5,083
Try changing your COD (class of device) in main.conf.
During the Bluetooth discovery process, certain devices may "see" your device but will not ennumerate it in their list of available devices because it is not advertising the major or minor class that the remote device is looking for. In this case you would probably want to change your laptop cod to something that traditionally has an audio sink role, such as a speaker or headset so your TV will ennummerate it in its list. See the Bluetooth SIG assigned numbers for reference.
The last 3 lines of /etc/bluetooth/audio.conf are commented, just uncomment those lines deleting the hash in front of them, leave like that:
[A2DP]
SBCSources=1
MPEG12Sources=0
This worked for me, now just connect to your headset and use a2dp. It should shows Bluetooth headset on audio configurations.
sourav c.
  • 46,120
