I've installed Popcorn Time using the following command:
cd
wget https://raw.github.com/hotice/webupd8/master/popcorn-build
chmod +x popcorn-build
./popcorn-build
that I found here.
How can I uninstall it?
cd
./popcorn-build
that I found here.
Since this is my script (rewritten a bit by Webupd8's Andrew), this should work :
uninstalling Popcorn Time :
sudo rm -r /opt/Popcorn-Time
sudo rm /usr/share/pixmaps/popcorntime.png
sudo rm /usr/share/applications/popcorn-time.desktop
sudo rm /usr/bin/popcorn-time
remove the NodeJS
sudo add-apt-repository -r ppa:chris-lea/node.js
sudo apt-get remove nodejs
sudo rm /usr/bin/node
remove Ruby :
if 12.04 : sudo apt-get remove rubygem
if 13.04 or higher : sudo apt-get remove ruby-compass
remove Git, NPM :
sudo apt-get remove git npm
remove 'libudev' symlink :
if 32 bits : sudo rm /lib/i386-linux-gnu/libudev.so.0
if 64 bits : sudo rm /lib/x86_64-linux-gnu/libudev.so.0
Once it's done, you can clean up :
sudo apt-get autoremove -y
sudo apt-get autoclean
sudo apt-get update
