28
How can I install Popcorn Time beta ?
I see on their website that they only offer a 64-bit installation files, but the sources are open.
I can't use the usual ./configure && make. So, what can I do ?
MrVaykadji
  • 5,965
This script will help you build Popcorn Time dev-0.3 on Ubuntu Linux from the Github sources.
It works flawlessly on Ubuntu 12.04 and 14.04 64bits, but should work with every maintained version and every architecture.
To build and install Popcorn-Time from sources, you'll need nodejs and npm. npm uses bower and grunt-cli to build the files: that's why you can't use the usual ./configure
Note : there currently is 1 bug with the installation files : nodejs binary being misnamed, you can fix it by a simple symlink from 'nodejs' to 'node'.
Note : on 12.04, there's no libudev.so.1, so we'll need to symlink it from libudev.so.0
HOW-TO
  1. Copy-paste the following lines into a text file, I'll name it script for the example.
  2. Then, use your terminal and launch the script:
    bash script
  3. Follow the instructions on the screen:
    • Accept the disclaimer
    • Choose the plateform you want to build for (mac,win,linux32-64)
    • Install Popcorn-Time with shortcuts and commandline options if you wish
    • Remove building files if you don't want them anymore
    • Remove the packages used by this script to build PT if you don't want them in the future
    • voila.
This will take about 10-30min to complete.
#!/bin/bash
#Written by MrVaykadji - http://github.com/MrVaykadji
#Thanks to Andrew for func_apt, nodejs PPA and libudev fix - http://webupd8.org
#licensed under GPLv3
#for Ubuntu 12.04 and newer
installdir="/opt"
version="master"
OfficialURL="http://popcorntime.io"
githubURL="https://github.com/popcorn-official/popcorn-app"
issueURL="https://github.com/popcorn-official/popcorn-app/issues"
icon="https://github.com/popcorn-official/popcorn-app/raw/master/src/app/images/icon.png"
log="$HOME/popcorn-build.log"
buildscriptURL="https://raw.githubusercontent.com/MrVaykadji/misc/master/Popcorn-Time/0.3.0/"
buildscript="build-popcorn"
[ $(arch) == "x86_64" ] && arch=64 || arch=32
buildtime="`date +%Y.%m.%d-%Hh%M`"
#FUNCTIONS
func_apt() {
for lock in synaptic update-manager software-center apt-get "dpkg " aptitude
do
 if ps -U root -u root u | grep "$lock" | grep -v grep > /dev/null; then
  echo "
Unexpected Error:
Please close $lock then try again.";
  exit 1
 fi
done
func_root() {
[ "$EUID" == "0" ] &&
echo "Error. You need to run this without 'root' or 'sudo' privileges." &&
exit 2
func_error() {
[ -n $error ] && return 0
echo "
Unexpected Error:
cat $log
echo "
Please try again."
exit 1
func_clean() {
case $1 in
    -save)
        sudo mkdir -p /tmp/popcorn-config
        sudo cp -r $HOME/.config/Popcorn-Time/data /tmp/popcorn-config/ &> /dev/null
        sudo rm -rf $HOME/.config/Popcorn-Time/*
        sudo cp -r /tmp/popcorn-config/data $HOME/.config/Popcorn-Time/ &> /dev/null &&
        sudo chown -Rf $USER:$USER $HOME/.config/Popcorn-Time/data &&
        sudo chmod -R 774 $HOME/.config/Popcorn-Time/data
    -all)
        sudo rm -rf $installdir/Popcorn-Time /usr/share/pixmaps/popcorntime.png /usr/bin/popcorn-time $HOME/tmp $HOME/popcorn-app-$version $HOME/npm-debug.log $HOME/.npm $HOME/.cache/bower $HOME/.config/configstore/insight-bower.yml $HOME/.config/configstore/update-notifier-bower.yml $HOME/.local/share/bower $log $HOME/$version.zip $HOME/.npm/
    -package)
        sudo apt-get purge nodejs -y &> /dev/null &&
        sudo apt-get autoremove -y &> /dev/null &&
        sudo rm -rf /usr/bin/node &&
        sudo add-apt-repository -yr ppa:chris-lea/node.js &> /dev/null &&
        echo -e "... Done.\n"
    -building)
 sudo rm -rf $HOME/tmp $HOME/popcorn-app-$version $HOME/npm-debug.log $HOME/.npm $HOME/.cache/bower $HOME/.config/configstore/insight-bower.yml $HOME/.config/configstore/update-notifier-bower.yml $HOME/.local/share/bower $log $HOME/.npm &&
esac
func_ptexists() {
if [ "$1" == "-update" ] ; then
    func_clean -save
else
    [ -e "$installdir/Popcorn-Time" ] &&
    read -p "
WARNING: Popcorn-Time is already installed in '$installdir' and will be erased. Do you want to keep the configuration files (bookmarks, watched list, settings, ...) [y/n] ? "
    if [ "$REPLY" == "y" ] ; then
        func_clean -save
    else
    fi
    sudo rm -rf /usr/share/applications/popcorn-time.desktop
fi
func_clean -all
func_dependencies() {
#package dep
[[ -n `egrep -v '^#|^ *$' /etc/apt/sources.list /etc/apt/sources.list.d/* | grep chris-lea/node.js` ]] && nodeppa=1 || nodeppa=0
if [ -n "`dpkg-query -W -f='${Status}\n' nodejs wget unzip | grep not`" ] || [ $nodeppa == "0" ] ; then
    echo "- Checking for dependencies 'nodejs', 'wget' and 'unzip'..."
    sudo apt-add-repository -y ppa:chris-lea/node.js &> $log &&
    sudo apt-get update &> $log
    sudo apt-get install nodejs wget unzip -y &> $log && echo -e "  ...Ok !" || error=1
    func_error
fi
#npm dep
if [ -e "/usr/lib/node_modules/bower" ] && [ -e "/usr/lib/node_modules/grunt-cli" ] ; then
    echo -e "\n- Updating NPM 'grunt-cli' and 'bower'..."
else
    echo -e "\n- Installing NPM 'grunt-cli' and 'bower'..."
fi
sudo npm install -g grunt-cli bower &> $log && echo -e "  ...Ok !\n" || error=1
func_error
#repair broken nodejs symlink
[ ! -e /usr/bin/node ] && sudo ln -s /usr/bin/nodejs /usr/bin/node
#symlink libudev.so on 12.04
[ `lsb_release -cs` == "precise" ] && [ ! -e /lib/$(arch)-linux-gnu/libudev.so.1 ] && sudo ln -s /lib/$(arch)-linux-gnu/libudev.so.0 /lib/$(arch)-linux-gnu/libudev.so.1
func_build() {
#get sources
echo "- Downloading sources (branch:$version) from GitHub..."
cd
wget $githubURL/archive/$version.zip -O $version.zip &> $log && unzip -o $version.zip &> $log && rm $version.zip && echo -e "  ...Ok !\n" || error=1
func_error
#npm
cd popcorn-app-$version
echo "- Running 'npm install'..."
sudo chown -Rf $USER:$USER $HOME/popcorn-app-$version/ $HOME/tmp $HOME/.npm
npm install --yes &> $log && echo -e "  ...Ok !\n" || error=1
func_error
#build
 buildcommand="linux$arch"
else
 buildvar=0
 echo -e "You can build for this machine only (linux$arch) or for all platforms, including : Mac, Windows, Linux 32-bits, Linux 64-bits.\n\nFor what platforms do you wish to build (for multiple builds, separate each platform with a comma)"
 read -p "[mac/win/linux32/linux64/all] : " input
 IFS=',' read -a options <<< "$input"
 shopt -s extglob
 for option in "${options[@]}"; do
    case "$option" in
        win|mac|linux32|linux64|all)
            buildcommand="${buildcommand:+$buildcommand,}$option"
            buildvar=1;;
            printf 'Invalid option "%s" ignored.\n' "$option";;
    esac
 done
 if (( !buildvar )); then
    echo "Incorrect input. Default build 'linux$arch' selected."
 fi
 [[ -n "`echo $buildcommand | grep all`" ]] && buildcommand="all"
fi
echo -e "\n- Building with 'grunt'..."
grunt build --platforms=$buildcommand &> $log && echo -e "   ...Ok !\n" || error=1
func_error
echo -e "Popcorn-Time has been built in :\n  «$HOME/popcorn-app-$version/build/releases/Popcorn-Time/»\n"
func_install() {
[ "`echo $buildcommand | grep -v linux$arch`" ] && exit 0
if [ "$1" != "-update" ] ; then
read -p "Do you wish to install Popcorn-Time on this computer [y/n] ? "
[ "$REPLY" != "y" ] && exit 0
fi
sudo mkdir -p $installdir
sudo cp -r $HOME/popcorn-app-$version/build/releases/Popcorn-Time/linux$arch/Popcorn-Time $installdir
echo -e "\n- Creating commandline launcher..."
echo "#!/bin/bash
echo \"Popcorn Time
[ \"\$EUID\" == \"0\" ] && echo \"Error: You need to run this without 'root' or 'sudo' privileges.\" && exit 2
helpsection() {
echo \"Version $version
Built on $buildtime from $githubURL
Official website : $OfficialURL
Options:
  -h, --help        Display this help.
  -q,--quiet        Launch Popcorn-Time without output.
  --flush       Flush databases.
  --fix-node        Fix the node-webkit 'blank' error.
  --uninstall       Uninstall Popcorn-Time.
  --issue       Report an issue.
  --build       Build latest version from sources.\"
flush_all() {
echo \"- Flushing databases...\"
uninstall() {
echo \"- Uninstalling Popcorn-Time and removing configuration files...\"
sudo bash $installdir/Popcorn-Time/uninstall.sh
popcorntimequiet() {
echo \"Starting...\"
nohup $installdir/Popcorn-Time/Popcorn-Time &> /dev/null &
exit 0
popcorntime() {
reportissue() {
echo \"Here is what a great bug report looks like:
Describe the problem here
Version: $version for Linux $arch bits
         Built on $buildtime
Downloaded from: $githubURL
OS: `lsb_release -si` `lsb_release -sr` `arch`
Connection: X mbps
How to reproduce:
 - Step 1
 - Step 2
 - Step 3
Actual result:
 - X goes wrong
Expected result:
 - X should go like that
xdg-open $issueURL &> /dev/null
fix_node() {
echo \"Fixing node-webkit...\"
rm -rf $HOME/.config/node-webkit
build_pt() {
cd
echo \"Building script fetched from GitHub...\"
wget -q $buildscriptURL$buildscript
bash $buildscript -update
case \$1 in
    -h|--help)
        helpsection
    --uninstall)
        uninstall
    --flush)
        flush_all
    --fix-node)
        fix_node
    --issue)
        reportissue
    -q|--quiet)
        popcorntimequiet
    --build)
        build_pt
        popcorntime
esac" | sudo tee /usr/bin/popcorn-time &> /dev/null
sudo chmod +x /usr/bin/popcorn-time
echo -e "    «/usr/bin/popcorn-time»\n"
echo "- Creating launcher... "
sudo wget $icon -qO /tmp/popcorntime.png && sudo cp /tmp/popcorntime.png /usr/share/pixmaps/
echo "[Desktop Entry]
Comment=Watch movies in streaming with P2P.
Comment[fr]=Regarder des films en streaming.
Name=Popcorn Time
Exec=/usr/bin/popcorn-time
StartupNotify=false
Type=Application
Icon=popcorntime
Actions=ForceClose;ReportIssue;FlushDB;FixNode;BuildUpdate;
Keywords=P2P;streaming;movies;tv;series;shows;
Keywords[fr]=P2P;streaming;films;séries;télévision;tv;
[Desktop Action ForceClose]
Name=Force close
Name[fr]=Forcer la fermeture
Exec=killall Popcorn-Time
OnlyShowIn=Unity;
[Desktop Action ReportIssue]
Name=Report Issue
Name[fr]=Rapporter un problème
Exec=sh -c \"popcorn-time --issue\"
OnlyShowIn=Unity;
[Desktop Action FlushDB]
Name=Flush databases
Name[fr]=Vider les bases de données
Exec=sh -c \"killall Popcorn-Time ; rm -rf $HOME/.config/Popcorn-Time ; /usr/bin/popcorn-time\"
OnlyShowIn=Unity;
[Desktop Action FixNode]
Name=Fix Node-Webkit
Name[fr]=Réparer Node-Webkit
Exec=sh -c \"rm -rf $HOME/.config/node-webkit ; killall Popcorn-Time ; /usr/bin/popcorn-time\"
OnlyShowIn=Unity;
[Desktop Action BuildUpdate]
Name=Build latest version
Name[fr]=Construire la dernière version
Exec=sh -c 'killall Popcorn-Time ; xterm -fa monaco -fs 13 -bg black -fg white -title \"Build latest Popcorn Time\" -e \"popcorn-time --build\" ; /usr/bin/popcorn-time'
OnlyShowIn=Unity;" | sudo tee /usr/share/applications/popcorn-time.desktop &> /dev/null
sudo chmod +x /usr/share/applications/popcorn-time.desktop
echo -e "    «/usr/share/applications/popcorn-time.desktop»\n"
echo "- Creating uninstall script..."
echo "#!/bin/bash
#uninstallation script for Popcorn-Time
#clean directory
#clean config
#clean icon
sudo rm -rf /usr/share/pixmaps/popcorntime.png
#clean launchers
sudo rm -rf /usr/bin/popcorn-time
" | sudo tee $installdir/Popcorn-Time/uninstall.sh &> /dev/null
sudo chmod +x $installdir/Popcorn-Time/uninstall.sh
echo -e "    «$installdir/Popcorn-Time/uninstall.sh»\n"
func_end() {
if [ "$buildcommand" == "linux$arch" ] ; then
    func_clean -building
    sudo rm -rf $0
 else
  read -p "Do you wish to remove all the building files [y/n] ? "
  [ "$REPLY" == "y" ] && func_clean -building
 fi
fi
if [ "$nodeppa" == "0" ] ; then
    read -p "Do you wish to uninstall the packages installed for this build, they will be needed in case of new build [y/n] ? "
    [ "$REPLY" == "y" ] && func_clean -package
fi
#SCRIPT#
func_root
func_apt
echo "
Popcorn-Time $version for Ubuntu-Linux
Popcorn Time streams movies from Torrents.
Downloading copyrighted material may be illegal in your country.
!!! Use at your own risk !!!
sudo test
case $1 in
    -update)
        option="-update"
        [ -n "$1" ] && echo -e "\nUnauthorized option '$1' will be ignored."
esac
func_ptexists $option
func_dependencies
func_build $option
func_install $option
func_end $option
echo "=================================================
Popcorn-Time is now installed !
Type «popcorn-time --help» for more information."
exit 0
Uninstallation
A simple popcorn-time --uninstall should be enough. If not, clear those files :
  • /opt/Popcorn-Time
  • ~/.config/Popcorn-Time
  • /usr/share/pixmaps/popcorntime.png
  • /usr/bin/popcorn-time
  • /usr/share/applications/popcorn-time.desktop
MrVaykadji
  • 5,965
Manually :
1) Get the files
Clone the repo with git (install it if needed) :
git clone https://git.popcorntime.io/popcorntime/desktop.git
2) Install node.js
sudo add-apt-repository ppa:chris-lea/node.js
sudo apt-get update
3) Install node.js requiered dependencies
4) enter the directory
cd desktop
5) Install Popcorn-Time dependencies
npm install
6) Build with grunt
grunt build
7) Get the built executable
You'll find the executable inside the build/releases folder
7bis) Start the live-development
grunt start
MrVaykadji
  • 5,965
