I want to create this folder: $HOME/a/b/c/d while $HOME/a has not yet been created! Is it possible with one line in Terminal?
Asked
Active
Viewed 1.5k times
12
17
You can use the command mkdir with -p option to create a folder inside another non-existent folder. Consider an example,
mkdir -p "$HOME/a/b/c/d"
Where the folders a,b,c and d do not exist in home before running the command. After execution of the command all these folders will be created recursively inside one another.
You can see from man mkdir
-p, --parents
no error if existing, make parent directories as needed
sourav c.
- 46,120
Here is the answer to the question,below command will do the job you want in just the way you want :) This can be done with mkdir (make directory command) as shown below:
root@test:~# sudo mkdir -p /abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
root@test:~#
If you want it to show you the directories it created while it is working then use verbose with it as shown below:
root@test:~# sudo mkdir -pv /abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
mkdir: created directory `/abcd'
mkdir: created directory `/abcd/efgh'
mkdir: created directory `/abcd/efgh/ijkl'
mkdir: created directory `/abcd/efgh/ijkl/mnop'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst/uvwx'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst/uvwx/yz/'
root@test:~#
Enjoy!! :)
Hrish
- 2,399
