How to create a complete directory structure with a single command?
By this question I mean, if I wanted to create a directory structure like below in one go using a command.
/abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
then what command shall I use?
Zanna
  • 72,312
Hrish
  • 2,399
mkdir -p /abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
mkdir is "make directory"
The -p option creates the parent directories if they do not already exist.
Carl H
  • 6,316
  • 28
  • 42
Here is the answer to the question,below command will do the job you want in just the way you want :) This can be done with mkdir (make directory command) as shown below:
root@test:~# sudo mkdir -p /abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
root@test:~#
If you want it to show you the directories it created while it is working then use verbose with it as shown below:
root@test:~# sudo mkdir -pv /abcd/efgh/ijkl/mnop/qrst/uvwx/yz/
mkdir: created directory `/abcd'
mkdir: created directory `/abcd/efgh'
mkdir: created directory `/abcd/efgh/ijkl'
mkdir: created directory `/abcd/efgh/ijkl/mnop'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst/uvwx'
mkdir: created directory `/abcd/efgh/ijkl/mnop/qrst/uvwx/yz/'
root@test:~#
Enjoy!! :)
Hrish
  • 2,399
