I am having a problem using wired connection for Ubuntu 13.10. The problem started suddenly. However I was able to solve it using the answer given in the following post:
Ubuntu 12.04 Dell 6400 no network
It worked perfectly. But now again I am unable to connect to the internet. I tried using the same solution but it was of no use. I have reinstalled the driver for Realtek Ethernet Controller (r8168 ==the latest version) using the answer given in this post:
Wifi and Ethernet connectivity problems after upgrading to 12.04
But these solutions are not solving my problem.
sudo ifconfig :
eth0      Link encap:Ethernet  HWaddr b8:ac:6f:76:c1:2c
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:985 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1351 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:95359 (95.3 KB)  TX bytes:149074 (149.0 KB)
          Interrupt:46 Base address:0xa000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1032 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1032 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:89902 (89.9 KB)  TX bytes:89902 (89.9 KB)
wlan0     Link encap:Ethernet  HWaddr 20:7c:8f:10:08:d0
          inet addr:192.168.43.74  Bcast:192.168.43.255  Mask:255.255.255.0
          inet6 addr: fe80::227c:8fff:fe10:8d0/64 Scope:Link
          RX packets:15527 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16374 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:10844956 (10.8 MB)  TX bytes:2728215 (2.7 MB)
lsmod |grep r8168
r8168                 387138  0
 dmesg |tail
[ 3140.976810] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 3156.224464] cfg80211: Calling CRDA to update world regulatory domain
[ 3156.233144] cfg80211: World regulatory domain updated:
[ 3156.233152] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 3156.233156] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 3156.233161] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 3156.233164] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 3156.233168] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 3156.233172] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 3171.265877] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Tanvir
  • 982
