[Preface: I have seen similar questions, but that did not help me and so this new question. To explain in more detail, I followed the steps in How do I resolve unmet dependencies after adding a PPA?, without rectifying the problem]
I am trying to install ccmake.
However, I get the following error:
sudo apt-get install cmake-curses-gui
Reading package lists... Done
Building dependency tree
 cmake-curses-gui : Depends: cmake (= 2.8.7-0ubuntu4)
I tried sudo apt-get -f install, but it did not help.
I am unable to find broken packages either.
cmake-curses-gui depends on cmake (= 2.8.7-0ubuntu4) for a precise installation.
If you're unable to install this particular version it means that you installed a different version on your system.
Try first to uninstall cmake:
sudo apt-get remove cmake
And install again cmake-curses-gui:
If it doesn't work check if you're not pulling a different version of cmake from a ppa.
