These are the contents of the stock ~/.profile that came with my 13.10 (commented lines removed):
if [ -n "$BASH_VERSION" ]; then
if [ -f "$HOME/.bashrc" ]; then
. "$HOME/.bashrc"
fi
fi
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
This is inherited from Debian but why did Canonical decide to keep it? As far as I know, it's not the standard *nix way and I have seen various systems where this did not happen, so I assume they must have had a good reason to. This can cause unexpected behavior when running login shells (such as when sshing into the machine for example) where the user would not expect to have ~/.bashrc sourced.
The only benefit I can think of is to not confuse the user with many startup files and allow them to edit .bashrc alone and have that read irrespective of shell type. That, however, is a dubious benefit since it is often useful to have different settings for login and for interactive shells and this blocks you from doing so. Also, login shells are very often not run in a graphical environment and that can cause errors and warnings and problems (oh my!) depending on what you've set in those files.
So why does Ubuntu do this, what am I missing?
