59
I have an ubuntu system and I want to replace my openjdk with oracle-jdk.
However if I remove my open-jdk and then install oracle-jdk, when I try to install some packages they want to install openjdk and I don't want this.
Is there any way to install those packages on top of oracle-jdk? One of those packages is freemind.
Seth
  • 59,332
littleali
  • 727
You can completely remove the OpenJDK and fresh Install Oracle Java JDK by following these steps:
  1. Remove OpenJDK completely by this command:
    sudo apt-get purge openjdk-\*
  2. Download the Oracle Java JDK here.
    Note: download appropriate file, for example if your system is x64 Ubuntu (i.e, Debian) the download file is named like this: jdk-8u51-linux-x64.tar.gz
    To find which version is your OS, check here
  3. Create a folder named java in /usr/local/by this command:
    sudo mkdir -p /usr/local/java
  4. Copy the Downloaded file in the directory /usr/local/java. To do this, cd into directory where downloaded file is located and use this command for copying that file to /usr/local/java/:
    sudo cp -r jdk-8u51-linux-x64.tar.gz /usr/local/java/
  5. CD into /usr/local/java/ directory and extract that copied file by using this command:
    sudo tar xvzf jdk-8u51-linux-x64.tar.gz
  6. After extraction you must see a folder named jdk1.8.0_51.
  7. Update PATH file by opening /etc/profile file by the command sudo nano /etc/profile and paste the following at the end of the file:
    JAVA_HOME=/usr/local/java/jdk1.8.0_51
    PATH=$PATH:$HOME/bin:$JAVA_HOME/bin
    export JAVA_HOME
    export PATH
  8. Save and exit.
  9. Tell the system that the new Oracle Java version is available by the following commands:
    sudo update-alternatives --install "/usr/bin/java" "java" "/usr/local/java/jdk1.8.0_51/bin/java" 1
    sudo update-alternatives --install "/usr/bin/javac" "javac" "/usr/local/java/jdk1.8.0_51/bin/javac" 1
    sudo update-alternatives --install "/usr/bin/javaws" "javaws" "/usr/local/java/jdk1.8.0_51/bin/javaws" 1
  10. Make Oracle Java JDK as default by this following commands:
    sudo update-alternatives --set java /usr/local/java/jdk1.8.0_51/bin/java
    sudo update-alternatives --set javac /usr/local/java/jdk1.8.0_51/bin/javac
    sudo update-alternatives --set javaws /usr/local/java/jdk1.8.0_51/bin/javaws
  11. Reload sytem wide PATH /etc/profile by this command:
    source /etc/profile
  12. Reboot your system.
  13. Check Java JDK version by java -version command . If installation is succesful, it will display like the following:
    java version "1.8.0_51"
    Java(TM) SE Runtime Environment (build 1.8.0_51-xxx)
    Java HotSpot(TM) Server VM (build 25.51-xxx, mixed mode)
That's it!
Note: We Assumed that the downloaded file is named jdk-8u51-linux-x64.tar.gz and used this name in all the commands used in steps 2, 4 and 5. It may depends on the type of O.S, processor type (i.e., 32bit or 64bit)
Nithi2023
  • 956
21
You don't need to remove openjdk in order to use / install the oracle's jdk. Just install the oracle's jdk and configure which java you want to use by configuring it with:
sudo update-alternatives --config java
You can find more help here: https://help.ubuntu.com/community/Java
Seth
  • 59,332
Myx
  • 341
11
Tested in Ubuntu 14.04/16.04. In three steps:
  1. Install the oracle-java7-installer (or oracle-java8-installer) from the webupd8team repository
    sudo add-apt-repository ppa:webupd8team/java
    sudo apt-get update
    sudo apt-get install oracle-java7-installer
  2. Make sure it works with the following command:
    java -version
    It should display something similar to:
    java version "1.7.0_76"
    Java(TM) SE Runtime Environment (build 1.7.0_76-b13)
    Java HotSpot(TM) 64-Bit Server VM (build 24.76-b04, mixed mode)
  3. (Optional) Remove the open-jdk if you really want/need to:
You can find more information here
toto_tico
  • 285
After removing openjdk, try this approach that worked for me:
Install oracle jdk 7 on ubuntu server (tested with ubuntu 12.0.4)
sudo apt-get install python-software-properties
sudo apt-get update
some more info here: https://launchpad.net/~webupd8team/+archive/java
(note to adapt this for your version of jdk)
mihaic
  • 91
