I'm having serious problems installing Ubuntu on my Asus Rampage IV Extreme/i7, in fact in any version of Linux at all.
Here are the steps I'm following:
  1. Direct boot Kubuntu 13.10 from DVD - Sometimes installer starts, sometimes not (freeze on Kubuntu logo) - when it starts it installs just fine, after that login screen shows after login freeze while being on "hard drive" icon, however once it started don't know why...
  2. Direct boot Ubuntu 13.10 - freeze and stop reading from CD at install screen (this one with passing dots).
  3. 12.04 - same thing in both cases.
  4. Wubi 12.4 from Windows installed just to do it - install on Windows completes fine, after restart: "To show other install options press ESC now" then shows "0" and freezes.
  5. Recommended by manufacturer 11.4 same thing.
  6. OLE/openSUSE/other RedHat based - "waiting for hardware to initialize" or "starting udev..." before installation, then freezes.
Tried with different combinations of BIOS settings/install options like nomodprobe but nothing worked.
Is system incapable of handling any linux ?
EDIT - Specs:
Intel Core i7 4930K
Kingston HyperX DDR3 4x 8GB 1600 MHz CL9 XMP Beast
GeForce with CUDA GT210 Asus 1GB Silent HDMI & DVI (PCI-E) (DDR3)
WD VelociRaptor 500GB WD5000HHTZ (SATA/600,64MB) x2
Lite-ON DVD /-RW iHAS122-04 SATA
kamil
  • 49
pgr
  • 482
I have a bunch of questions/suggestions for clarification for you and others.
What do you mean by freeze? Sometimes linux could appear to be frozen but actually, it could just be a pci issue where no inputs are being accepts.
What part is freezing?
Have you tried USB installation over DVD installation? What are the steps you used to create the DVD(or USB)?
Here is a similar thread. Seems like you have a nVidia GPU, and it seems like your motherboard does not have an onboard display out. The solution mentioned is to use nomodeset when installing/booting to either liveCD or ubuntu itself. Of course this depends on what kind of freezing issues you are having.
Try to minimize possible hardware issues. I see that you have 2 HDD's attached. Disabling RAID may be worth a shot as well. The thread I linked also mentioned that there could be issues with multiple HDDs and noted it was better to isolate the linux installation on one drive though I do not understand the detailed logic behind that. Additionally, validate that your RAM is stable. Seems like there are hard freezing issues when the RAM is faulty. I see that you have 4 sticks. See what happens when you only use one. Note: Use 64-bit distros. 32-bit has a RAM limit.
I did not see anything about IOMMU settings on this mother but check if you have this. Sometimes keyboard/mouse will not work because of this which may be causing the "freezing". Depending on where it freezes, it may be worth it to try an external mouse/keyboard. Avoid USB 3.0 if possible.
UEFI can also cause complications. Did you boot the installation device in UEFI mode?
I'd suggest adding more details to your post with these questions.
Mr.Lee
  • 891
Actually after time it was Linux problem itself. Under Kernel 3.15 rc3 everythings runs fine.
pgr
  • 482
-2
This is caused by RAID please make sure you disable it in the BIOS and then try installing :)
please let me know if it helps
-3
Try some kernel modificators:
lacpi=off
acpi=off
noapic
nolapic
nodmraid
nomodeset
you know what I mean. Play a little with one or some o them. It worked for me.
BuZZ-dEE
  • 14,533
