I'm newbie in Ubuntu. After dist-upgrade, system doesn't work correctly. GRUB background has been changed to Kali and in menu, Ubuntu has been replaced by Kali.
Terminal doesn't work either. On start-up, system reports many errors. Funny thing is that system identifies itself as Kali 2.
Ubuntu 15.10 + Xfce on ASUS K43BR (64-bit).
Help me please!
After a while looking around , I decided to do a fresh install but making backup of data is so boring! so i didn't do anything, grub works fine. theme is changed to Kali but core is fine. by using Ubuntu default desktop environment, I have removed Xfce and many extra packages installed before. then by cleaning up the system I installed them again. errors are gone and system works fine. the only problem is Software center which doesn't work at all. but don't worry, synaptic is here.
sudo apt-get clean
sudo apt-get autoclean
sudo apt-get update
sudo apt-get purge xfconf xfce4-utils xfwm4 xfce4-session xfdesktop4 exo-utils xfce4-panel xfce4-terminal  thunar
sudo apt-get autoremove
sudo apt-get -f install
sudo apt-get install xfce4
sudo apt-get install xfce4-goodies
