How do I fully integrate Periscope with Nautilus so that I can right-click on a video file and get subtitles downloaded? I have downloaded all the appropriate files and Periscope is fully installed. The problem is getting it fully integrated with Nautilus or something like Nautilus. I do not want to operate at the the console
ALAN
  • 139
Here's a simple Nautilus script that should do the job:
#!/bin/bash
# NAME:         Get_subtitles
# AUTHOR:       (c) 2014 Glutanimate
# DEPENDENCIES: periscope (https://code.google.com/p/periscope/)
# LICENSE:      MIT license (http://opensource.org/licenses/MIT)
LANGUAGE="en"
while [ $# -gt 0 ]; do
    MOVIE="$1"
    periscope "$MOVIE" -l "$LANGUAGE"
    shift
done
Installation instructions.
Note: I don't have periscope installed so I'd appreciate your feedback on whether the script works or not.
Glutanimate
  • 21,763
Here is one particular way to do this:
First up, install python support in nautilus by installing python-nautilus and python-notify:
sudo aptitude install python-nautilus python-notify
Then install periscope.
Now you need to copy the periscope-nautilus.py script into the ~/.nautilus/python-extensions folder:
cd ~/.nautilus/python-extensions
wget http://periscope.googlecode.com/svn/trunk/bin/periscope-nautilus/periscope-nautilus.py
If you want to change the default languages, run periscope once, a file named "config" will be created under ~/.config/periscope. Update this file to reflect your preferred languages. (English example below, you can use commas to have multiple languages)
lang = en
Restart nautilus.
nautilus -q
Open nautilus and go find a video file, right click and now you've got the notification to see if corresponding subtitles were found.
