My girlfriend has to create a samba server to create file sharing possibilities between Ubuntu and multiple Windows 7 computers as a school project. Her teacher is unable to assist her, so I tried to help her a bit.
I have tried multiple guides on how to set up a Samba network (This, this and this), but each of them seems a totally different approach and none of them seem to work.
It could be that I am doing something wrong, but the computers just don't seem to connect, which could be caused by anything...
Summary of what I tried:
  • Install Samba
  • Setup the Server Settings (my Windows workgroup is just 'WORKGROUP' which is the default option)
After this I tried a myriad of things:
  1. Editing the Samba config file to share a folder (as per the official Ubuntu guide)
  2. using the Samba GUI to share a folder
  3. adding new users to samba
  4. Checking if my file and printer sharing option on Windows is enabled
  5. and a lot more which I probably forgot I did
After all this, the Windows computers still don't recognize the file share. It does not show up on the network and running the IP-adres also does not work.
Does anybody have a simple step by step guide on how to create a Samba server to use with Ubuntu 12.04 and Windows 7. It only has to be a simple server, with a enabled password and some files in it. If there is better software than Samba for this job, please let me know and thanks for the help!
Michael
  • 464
First install Samba :
sudo apt-get install samba
Now edit samba config file :
gksu gedit /etc/samba/smb.conf
scroll down to workgroup = WORKGROUP ( or any other work-group)
Now see authentication section :
 #     security = user
Remove the “#” at the front of the line.
To create a share :
[share]
    comment = (Name it as you want )
    path = /path/to/share/folder (path you put your share )
    browsable = yes
    guest ok = yes ( in no it will prompt for password)
    read only = no
    writeable = yes
    create mask = 0775 (permission drwxrwxr-x)
Now if you choose guest ok = no you should create a samba account :
let assume you have a user name user1
sudo smbpasswd user1
and give it password so when you share it will be for authetication.
sudo service smbd restart
sudo service nmbd restart
Now in windows try to connect to your share , it should be found .
Michael
  • 464
nux
  • 39,152
Make sure the users are also added to the linux machine, not just samba. They need to be added to both ubuntu and samba. Make sure the users are are also added to the Windows machines and their passwords match the samba passwords.
froy
