I've installed ubuntu, but now i can't boot to windows. Here is my boot repair output.
How can i solve this problem?
Wilf
  • 30,732
try this solution:
First boot on your Windows installation DVD and navigate to the section repair your computerif it finds your Windows installation, make sure it is unselected before clicking next, then click on Command prompt and run:
bootrec.exe /fixboot
bootrec.exe /fixmbr
then reboot and remove your installation DVD
if you don't have the installation DVD you can get Windows repair disk (Win7 example) manually created.
Just in case if after all facing any issues yet check on this
JoKeR
  • 7,062
You've got a mixed-mode (BIOS/EFI) installation: Windows is installed in BIOS/CSM/legacy mode on /dev/sdb and Ubuntu is installed in EFI/UEFI mode on /dev/sda. (Most such mixed-mode installations go the other way around.) Getting dual-boot working with OSes installed in differing modes is awkward at best and impossible at worst.
Given that Windows is less flexible that Linux on this score, my recommendation is to install a BIOS-mode version of GRUB for Linux. Try it this way:
  1. Boot to Linux.
  2. Using GParted, parted, or gdisk, create a ~1MiB partition at the very end of the disk. If you use GParted or parted, give it a bios_grub flag. If you use gdisk, give it a type code of EF02. It's possible that GParted and/or parted will balk at creating such a small partition, but gdisk will definitely do it.
  3. Reboot to a Linux live CD. Boot in BIOS/CSM/legacy mode. This can usually be achieved by selecting a boot option in the firmware's built-in boot manager that lacks the string "EFI" or "UEFI." Unfortunately, the exact procedures vary greatly from one computer to another, so you may need to experiment or ask for more help on this point.
  4. Run Boot Repair again and tell it to re-install GRUB.
At this point, you should be able to boot into both Linux and Windows in BIOS mode, with GRUB controlling the boot process. You might need to fiddle with your boot options to get a BIOS/CSM/legacy-mode boot to work as the default, though.
Unfortunately, some EFIs have bugs that can complicate matters with BIOS/CSM/legacy-mode booting from GPT disks. Check this Web page if you have problems getting GRUB to come up in BIOS/CSM/legacy mode. In a worst-case scenario, you might need to convert /dev/sda from GPT to MBR.
The alternative to this is to convert Windows to boot in EFI mode. This will require converting /dev/sdb from MBR to GPT and installing an EFI-mode Windows boot loader. This process is described here, in case you want to pursue it.
Rod Smith
  • 45,120
  • 66
  • 108
