When I install the software updates with "Update Manager", there is a pop up alert which tells me "The volume "boot" has only 0 byte disk space remaining
run sudo fdisk -l in a terminal, and output:
Disk /dev/sda: 500.1 GB, 500107862016 bytes 255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x0c7a859b Device Boot Start End Blocks Id System /dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT /dev/sda2 206848 280451071 140122112 7 HPFS/NTFS/exFAT /dev/sda3 280451072 618371071 168960000 7 HPFS/NTFS/exFAT /dev/sda4 618373118 976768064 179197473+ f W95 Ext'd (LBA) /dev/sda5 763730163 976768064 106518951 7 HPFS/NTFS/exFAT /dev/sda6 618373120 626370559 3998720 83 Linux /dev/sda7 626372608 630370303 1998848 82 Linux swap / Solaris 63.59 GB space **free** after /dev/sda7
lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 465.8G 0 disk ├─sda1 8:1 0 100M 0 part ├─sda2 8:2 0 133.6G 0 part ├─sda3 8:3 0 161.1G 0 part ├─sda4 8:4 0 1K 0 part ├─sda5 8:5 0 101.6G 0 part ├─sda6 8:6 0 3.8G 0 part / └─sda7 8:7 0 1.9G 0 part [SWAP] sr0 11:0 1 1024M 0 rom
