I'm running Ubuntu 12.04 LTS and I've followed the directions closely here:
How do I install LibreOffice 4?
sudo add-apt-repository ppa:libreoffice/libreoffice-4-1
sudo apt-get update
sudo apt-get dist-upgrade
to add the PPA repository and then run update / upgrade.
But when I actually run sudo apt-get upgrade I get:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I've downloaded the file manually (LibreOffice_4.2.1_Linux_x86-64_rpm.tar.gz) and executed it but I don't know how to fill out the command line arguments:
~/Downloads/LibreOffice_4.2.1.1_Linux_x86-64_rpm$ ./install
Usage: ./install [-a,--add] [-l,--link] [-U,--update] [-h,--help] <rpm-source-dir> <office-installation-dir>
Example: ./install . ~/libreoffice
I should probably be doing ./install -u /path/to/install/here
But how do I know where Libre Office is installed to right now? I'd like to upgrade my current version not install two side by side so I want to get these command line paramters right.
