So I set up a hotspot using hostapd, isc-dhcp-server and MASQUERADING.
The hotspot works and I can access Internet.
Problem
The connection speed is too slow.
When I connect to my hotspot (via android 4.1, Snapdragon S3), I see a connection speed of 65mbps, which drops down to 1mbps in seconds.
I know this isn't a hardware issue as I can easily get 24mbps (54mbps link) out of my ethernet connection on Windows (via connectify).
Information
iwconfig:
mon.wlan0 IEEE 802.11bgn Mode:Monitor Tx-Power=19 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11bgn Mode:Master Tx-Power=19 dBm
Power Management:off
iw list:
Wiphy phy0
Band 1:
Capabilities: 0x70
HT20
Static SM Power Save
RX Greenfield
RX HT20 SGI
RX HT40 SGI
No RX STBC
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT TX/RX MCS rate indexes supported: 0-7
Frequencies:
* 2412 MHz [1] (19.0 dBm)
* 2417 MHz [2] (19.0 dBm)
* 2422 MHz [3] (19.0 dBm)
* 2427 MHz [4] (19.0 dBm)
* 2432 MHz [5] (19.0 dBm)
* 2437 MHz [6] (19.0 dBm)
* 2442 MHz [7] (19.0 dBm)
* 2447 MHz [8] (19.0 dBm)
* 2452 MHz [9] (19.0 dBm)
* 2457 MHz [10] (19.0 dBm)
* 2462 MHz [11] (19.0 dBm)
* 2467 MHz [12] (19.0 dBm) (passive scanning, no IBSS)
* 2472 MHz [13] (19.0 dBm) (passive scanning, no IBSS)
* 2484 MHz [14] (disabled)
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
lspci -v:
0a:00.0 Network controller: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter (rev 01)
Subsystem: Hewlett-Packard Company Device 1795
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at d4500000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [58] Vendor Specific Information: Len=78 <?>
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [d0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [13c] Virtual Channel
Capabilities: [160] Device Serial Number <removed>
Capabilities: [16c] Power Budgeting <?>
Kernel driver in use: bcma-pci-bridge
0b:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
Subsystem: Hewlett-Packard Company Device 1818
Flags: bus master, fast devsel, latency 0, IRQ 43
I/O ports at 2000 [size=256]
Memory at d4404000 (64-bit, prefetchable) [size=4K]
Memory at d4400000 (64-bit, prefetchable) [size=16K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [140] Virtual Channel
Kernel driver in use: r8169
Ubuntu Release:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=13.10
DISTRIB_CODENAME=saucy
DISTRIB_DESCRIPTION="Ubuntu 13.10"
Linux pr3d4tOr 3.11.0-17-generic #31-Ubuntu SMP Mon Feb 3 21:52:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
What I have tried:
Transmission power:
prakhar@pr3d4tOr:~$ sudo iwconfig mon.wlan0 txpower 24Bit rate:
prakhar@pr3d4tOr:~$ sudo iwconfig mon.wlan0 rate autoDisable power management:
prakhar@pr3d4tOr:~$ sudo iwconfig mon.wlan0 power off Error for wireless request "Set Power Management" (8B2C) : SET failed on device mon.wlan0 ; Invalid argument.
I tried the above for wlan0 as well. No results. Can anyone guide as to what might be the problem?
