-1
I have already installed Apache OpenOffice 4.0.0 and would like to update it to the newer version which is Apache OpenOffice 4.0.1.
I have already downloaded the _deb.tar.cz files that were required but I can't seem to access the download through the terminal to install it.
What I tried was to open the Home/ directory but it can't seem to find it using the command:
cd /home/downloads/apache
What did I do wrong?
Zanna
  • 72,312
Go into the downloads folder and extract the tar.gz file by running,
cd /home/$USER/Downloads
OR
cd ~/Downloads
tar -xzvf filename.tar.gz
The above command extracts the .deb file inside Downloads directory.Then run the below command to install .deb file,
sudo dpkg -i filename.deb
Avinash Raj
  • 80,446
The D in downloads is a capital, so you need to enter
cd /home/user-name/Downloads
here user-name should be replaced with your user name, or you can use:
or
cd ~/Downloads
Understand the directory structure of Ubuntu (and Linux in general)
your Home directory as shown in nautilus is actually /home/user-name.
Zanna
  • 72,312
Null pointer
  • 2,607
