I'm try to change to my Desktop directory from the terminal.
Running
cd /home/desktop
gives an error in the terminal saying no directory found.
What am I doing wrong?
Running
cd /home/desktop
iBelieve's answer covers almost everything, but alternatively you can type
cd ~/Desktop/
the ~/ stands for /home/$USER/ or $HOME/
To answer your question mentioned in the quoted article:
The directory format is like this:
home
<username>
Desktop
Documents
so your command should be
cd /home/$USER/Desktop
To learn the directory structure, I'd suggest opening up the Home Folder app from the launcher on the left, and going to Computer and just exploring for a while. You won't be able to break anything outside of your home folder.
Because I haven't seen it mentioned yet, it should be noted that all directory names in Ubuntu (Linux) are case-sensitive. So even if you were in your correct home directory, executing a cd desktop should and will fail. If you look at @iBelieve's post, you can see that the Desktop directory starts with a capital 'D'. To get there, you will need to specify the correct case.
cd Desktop
To help you in the future, take a look at this Ubuntu help wiki page on using the terminal.
The following bash builtin commands are equivalent and they change the current working directory to your Desktop directory from your user home directory:
cd ~/Desktop # my favorite
cd ~; cd Desktop
cd ~ && cd Desktop
cd $HOME/Desktop
cd /home/username/Desktop # where 'username' is your user name
cd $CDPATH && cd Desktop
cd `locate -b '\Desktop'`
cd $(locate -b '\Desktop')
