I have Ubuntu 13.10 and I created a wireless hot spot using the network setting option and also tried to setup using AP-hotspot.
The problem is the one setup using network setting is not showing in my phone (Android 4.0) and when I start AP-hotspot it says already a process is running and if I stop and try to start again it says another process already running again.
Avinash Raj
  • 80,446
when I start AP-hot spot it says already a process is running and if I stop and try to start again it says another process already running again
Your command prompt should look like this,
$ sudo ap-hotspot start
Another process is already running
$ sudo ap-hotspot stop
Wireless Hotspot is not active
In this case whatever command you try, won't work. It would display the same error like above.
For this you have to remove hotspot.pid file present inside /tmp directory. So that only it would work.
sudo rm /tmp/hotspot.pid
And then try to start ap-hotspot by running,
To stop,
To configure,
sudo ap-hotspot configure
Avinash Raj
  • 80,446
Last time I needed to share the internet connection on a laptop with an Android mobile phone, I encountered similar issues: your Android may or may not recognize an Ad-Hoc network.
In the end I managed to create a hotspot Access Point using wifi-hostapd-ap, a GUI to create WiFi access point based on Hostapd. I had to disable DNS in NetworkManager to avoid wifi-hostapd-ap crashing, though.
See also:
landroni
  • 6,011
Install iw & execute following:
iw list
Look for supported interface section
Supported interface modes:
     * IBSS
     * managed
     * AP
     * AP/VLAN
     * monitor
If you have AP you're good.
Then follow this guide.
I have been through the pains of setting up Hotspot on an unsupported card.
Hope this helps.
Seth
  • 59,332
xyz
  • 1,836
