I have a very cheap Acer E1 series that is fairly new. I want to erase Windows completely from this laptop and put only Ubuntu 32 bit on it. I see that the BIOS is UEFI and there can be some issues in installing Ubuntu. So, I want to educate myself properly before I try this.
Is there a well tested guide for installing Ubuntu over Windows 8, in a UEFI laptop? I don't want dual boot. I want Windows off my laptop. Also, I might install more flavors of Linux alongside Ubuntu later.
fosslinux
  • 3,881
Because you have 4GB RAM in your Acer E1 laptop, and fast RAM (1600.0 MHz) at that, you will get better performance if you install the 64-bit Ubuntu instead of the 32-bit Ubuntu. Almost all of the apps that you can find are available for the 64-bit architecture, so there is no reason to select the 32-bit version of Ubuntu for the sake of application compatibility.
The canonical question for installing Ubuntu on a Windows 8 PC is: Installing Ubuntu on a Pre-Installed Windows 8 (64-bit) System (UEFI Supported).
karel
  • 122,292
  • 133
  • 301
  • 332
In addition to the links provided by karel, I recommend you read:
Those pages will give you a good understanding of what EFI is, how to use it, and (generally) how to install Linux using EFI. None of them is a step-by-step tutorial, though. In fact, such a tutorial is likely to be deficient because EFIs vary so much in user interfaces, and many of them have idiosyncratic bugs. Thus, when you follow such a tutorial, you're likely to get stuck at some point. That's where an understanding of the issues will be helpful.
Rod Smith
  • 45,120
  • 66
  • 108
