The AMD Catalystâ„¢ 13.12 Proprietary Linux x86 Display Driver can be used with Ubuntu 12.04.2 and 13.04 and the 14.1 Beta version can be used with Ubuntu 12.04.3 and 13.10.
Since, the beta version is known to have a lot of issues, I need to use the stable driver. Unfortunately, it is not working with 13.10 as it said in the documentation.
So, I need to download and install 12.04.2 and disable future updates to 12.04.3 for example.
How I can do this when the version of the Ubuntu that can be downloaded from the official website is 12.04.4 and how can I prevent update to next builds?
Braiam
  • 69,112
gotqn
  • 2,077
  • 30
  • 38
You can download old Ubuntu versions from http://old-releases.ubuntu.com/releases/12.04.2/
Now choose the version you want (12.04.2) and be sure if you want it 32 or 64bit Then click on it to download.
Now for the updates you can run the update manager from DASH then go to settings and beside check for updates choose never (see the image below)
Maythux
  • 87,123
In such a case I would pin down the dependencies but let the updates continue. In this manner security issues and high impact bugs in other packages will be dealt with.
In the case of this driver this means: Xserver <=1.14, Kernel <=3.11, Glib <=2.3
The way to do this is described here.
One issue with pinning is that you can not (that I know of) pin down to a version which is not available yet (do not upgrade above 3.5 while current is 3.3). So a direct pinning of this dependencies is not possible.
A way to deal with this is to pin down the current versions and if an update of one of these files occurs check if it still meets dependencies. If so, update the pinning, else leave it pinned.
To pin down to 12.04.2 on these dependencies you install 12.04.2 using the link provided by maythux and make a file /etc/apt/preferences with the following lines:
Package: x-server-common
Pin: version 2:1.11*
Pin-Priority: 550
Package: linux-image-generic*
Pin: version 3.2.*
Pin-Priority: 550
Package: libglib2.0
Pin: version 2.3*
Pin-Priority: 550
But the funny part is that looking at the dependencies I see no reason why the driver should not work with 12.04.4 Then looking at all the distro's they say to support it is obvious they made a list of the distro's on the market in the first half of 2013. So probably it is just a list with tested versions.
If I were you, I would give it a go and install 12.04.4 To be sure it won't break with future updates you put the following lines in the apt preferences file:
Pin-Priority: 550
Pin: version 3.11.*
Pin-Priority: 550
Package: libglib2.0
Pin: version 2.3*
Pin-Priority: 550
Requist
  • 2,439
  • 25
  • 32
