I have 9 viewports, 3x3 in Compiz Desktop Wall. Every time I boot up it starts with viewport 1, in the left top corner. I'd like it to start with viewport 5, in the center. How can I set that?
Thanks in advance!
Ctrl-C
  • 149
One solution I thought about was to run a command 1-2 seconds after startup in order to change your current workspace to the wanted one.
This answer here explains it perfectly:
Is there a command to go a specific workspace?
This answer explains how to run a command on startup
How do I start applications automatically on login?
In the "Command" field, you will need to input
bash -c 'sleep 3; wmctrl -o X,Y'
where X,Y the coordinates that you have to take from the 1st answer I posted.
hytromo
  • 4,891
