31
I'm trying to make a quicklist on the Workspace Switcher launcher that allows for quick switching to a certain workspace. (My friend sometimes uses my computer and just doesn't enjoy keyboard shortcuts, so I want to help him out.)
So is there a command one could type in a terminal that would force a certain workspace to be focused on?
Leron
  • 1,710
6 Answers6
47
You can use wmctrl.
Basics commands:
wmctrl -d to show all of your workspaces.
wmctrl -s <workspace_name> to change to a specific workspace.
If you are using Compiz, you will have to do a trick because Compiz "workspaces" are actually Viewports of a single Workspace.
Trick Instructions
Check the output of wmctrl -d For example, mine is:
0  * DG: 4098x2304  VP: 1366,0  WA: 0,23 1366x745  N/A
This means that actually I have one Workspace of 4098 x 2304 instead of what I "think" I have (nine "workspaces", 3 x 3).
I was at what was supposed to be "workspace" 2, but actually I was at viewport (VP) 1366,0 (4098 / 3 = 1366) as showed by the output above.
So this is how it works: we take the whole Workspace and divide for the numbers of "workspaces" we "think" we have. In my case: 4098 / 3 = 1366 and 2304 / 3 = 768.
If I want to go to my "workspace" 1, the command is:
wmctrl -o 0,0
Then, if I want to go to my "workspace" 4, the command is:
wmctrl -o 0,768
If I want to go to my "workspace" 8, the command is:
wmctrl -o 1366,1536
If I want to go to my "workspace" 9, the command is:
wmctrl -o 2732,1536
Got it? ;-)
The -o flag "truncates" their values. In other words it changes the "workspace" where the actual pixel is belonging to. The following are equivalent:
wmctrl -o 0,0
wmctrl -o 1365,767
muru
  • 207,228
desgua
  • 33,215
17
It is beautifully simple to achieve what you want with xdotool, which has multiple options for managing different workspaces (also known as 'desktops' within the program documentation). I find it can be very interesting and creative to string together commands from man xdotool; the commands I have formulated below might be useful in scripts.
Note: With some window managers, or if you are using compiz, you may need to use xdotool commands such as set_desktop_viewport and get_desktop_viewport. You may have to specify the commands in a different way like desgua suggests above, but for me the set_desktop and set_desktop_for_window commands proved most useful on a non-compiz system.)
(The solution is most useful for Xubuntu/Lubuntu users, or those who are not running compiz,etc.)
To list the number of current workspaces, enter
xdotool get_num_desktops
The following commands will only work if you have at least 1 other workspace.
To change focus to your workspace 1, just enter
xdotool set_desktop 1
Then to return to the default workspace, enter
xdotool set_desktop 0
The workspace just needs to be specified as the last value in the command (1 or 2 or 3, etc).
To find the number of the workspace you are currently on, you could use
xdotool get_desktop
These commands could be used in scripts and they should be very useful for achieving what you what.
For how to switch applications to a particular desktop, see my answer here:
For more useful options available for workspace switching, consult man xdotool.
I have implemented a script that does what you want. Here it is: https://github.com/norswap/wmov/blob/master/wmov.sh
It works indeed as described in desgua's post. It also the capabilities to send windows to other workspaces.
Norswap
  • 232
Going to a specific workspace and performing actions there can be implemented with Python and the library pyautogui, that enables Python scripts to perform mouse clicks, keystrokes, etc.
I wrote a short tutorial in the forum for Peppermint OS about starting an app on a specific workplace.
The_Fritz
  • 101
Update for desgua's answer - seems wmctrl -d outputs differently for Ubuntu 18.04.
This provides shortcuts for first, last and new workspaces too, or as a function you can call __ws_switch N where N is the workspace number.
0  * DG: 1920x1080  VP: 0,0  WA: 0,28 1920x1052  Workspace 1
1  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 2
2  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 3
3  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 4
4  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 5
5  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 6
6  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052  Workspace 7
7  - DG: 1920x1080  VP: N/A  WA: 0,28 1920x1052
Note the final blank workspace that isn't currently used. Assuming by the last workspace we mean the last workspace that is in use, the following could work:
cat << EOF >> "$script_dir"/ws.sh
#!/bin/sh
__ws_count() {
  __ws_counter="$(wmctrl -d | wc -l)"
  echo "$(( __ws_counter - 1 ))"
__ws_switch() {
  # Sanity test if "$1" is an int
  case "$1" in ''|*[^0-9]*)
    echo "Input '$1' is not an integer"
    return 1 ;;
  esac
  if test "$1" -gt "$(__ws_count)"; then
    echo "Workspace #$1 doesn't exist"
    return 1
  fi
  wmctrl -s "$1"
__ws_first() {
  __ws_switch 0
__ws_last() {
  __ws_counter="$(__ws_count)"
  __ws_switch "$(( __ws_counter - 1 ))"
__ws_new() {
  __ws_switch "$(( __ws_counter ))"
EOF
To add as a shortcut using xbindkeys, create the following shortcut files:
cat << EOF >> "$script_dir"/ws_first.sh
#!/bin/sh
. ./ws.sh
__ws_first
EOF
cat << EOF >> "$script_dir"/ws_last.sh
#!/bin/sh
. ./ws.sh
__ws_last
EOF
cat << EOF >> "$script_dir"/ws_new.sh
#!/bin/sh
. ./ws.sh
__ws_new
EOF
Then chmod +x ./ws.sh ./ws_first.sh ./ws_last.sh ./ws_new.sh to make them executable. Finally, to add to .xbindkeysrc:
cat << EOF >> ~/.xbindkeysrc
"$script_dir/ws_first.sh"
  Alt + Alt_L + w + f
"$script_dir/ws_last.sh"
  Alt + Alt_L + w + l
"$script_dir/ws_new.sh"
  Alt + Alt_L + w + n
EOF
EDIT: Don't forget to restart xbindkeys for changes to take effect:
killall xbindkeys && xbindkeys
Nick Bull
  • 182
There is a script called compiz-send.py on the compiz wiki that partly adresses your question: it is not a specific workspace but you can get to the one next to it.
With this you can issue a command
./compiz-dbus-send.py put put_viewport_left_key
./compiz-dbus-send.py put put_viewport_right_key
and have the viewport go 1 to the left or to right.
Rinzwind
  • 309,379
