I keep trying to install programs, by simply downloading the program, and clicking on it, but I see things are not that simple. Has anyone come up with a simple way to install different programs, without having to rely on Synaptic or Aptitude?
Example: I tried to install a .deb package. Went to the site, downloaded the package, opened up the command line (after making the file executable), the errors began. First there was a dependency file that was required, then there was a public key that was needed, man can someone make this a little bit simpler for a newbie. I think a newbie spends half of his time searching google to figure out how to make things work on Linux. Someone please help make this more simple? Tanks
Aaron
  • 6,764
To install a .deb package, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo dpkg -i <package_name>.deb
If you get a dependency error, you can run sudo apt-get install -f to download and install dependencies, otherwise; you'll have to install dependencies on your own.
For a new user, its easier to use synaptic , Ubuntu software Center, or apt to install packages. Take a look at How do I install applications in Ubuntu?
For more info on dpkg, see dpkg Command Cheat Sheet
Mitch
  • 109,787
Try to install .deb packages through gdebi,
 sudo gdebi filename.deb
Run the below command to install gdebi,
 sudo apt-get install gdebi
Installing the .deb file through gdebi will remove the dependency errors.
Avinash Raj
  • 80,446
