I'd like to upgrade from 10.10 to 11.04 but my ISP has a data-cap, limiting the amount I can download. Thankfully, traffic between 2am and 8am doesn't count towards this cap, but I'm seldom awake at 2am to kick the upgrade process off.
Is there a way I can schedule either the upgrade or the downloads required for the upgrade to run at a certain time?
Jorge Castro
  • 73,717
david w
  • 123
One solution is to download the installation CD and then use it as a local repository to perform the upgrade. Instructions are here:
Upgrading Using the Alternate CD/DVD
If your ISP allows you to download via BitTorrent at night, you can schedule Transmission to download the CD only at night from within the Edit ▸ Preferences ▸ Speed menu.
ændrük
  • 78,496
In general, you could download your updates with out installing them. Just become root, wait for 2am, and start downloading.
$ sudo bash
# sleep 5h
# apt-get dist-upgrade --download-only
You could create a cron job that executes the last command (especially for regular incremental updates). Then when you wake up, you can install the updates.
Unfortunately, the do-release-upgrade command (the recommended way to upgrade to the next Ubuntu) doesn't have a download-only option, so I'd stick with ændrük's CD download.
However, if you're feeling really adventurous, you could follow the instructions for setting up commandline upgrade and then run do-release-upgrade after a sleep. Note: I'd be pretty wary of installing updates when you're not there to see what might go wrong.
idbrii
  • 3,162
