I've had my Thinkpad T420 (integrated graphics, 8GB RAM, i5) for less than a month. I couldn't successfully install Natty (installer finished, but wouldn't boot), so I went with Maverick instead. On a daily basis, it completely freezes at least once, seemingly always when I'm in Firefox with multiple tabs open. My mouse can still move, but nothing is clickable, and I always have to do a hard restart.
I confirmed that this isn't a Unity bug, because I installed 10.10 in "command-line only" mode via the alternate install dvd, and manually installed X-server and fluxbox. The freezing still exists, without Unity or even Gnome running, whenever I do anything mildly resource-hungry in Firefox.
Thanks for any guidance.
oskar
  • 183
I have had my T420 for just over a week and am experiencing multiple problems with it. I initially installed Ubuntu 11.04 32bit which installed fine, but would crash several times each day. So I switched to the classic interface, but still was experiencing the type of anomaly that you describe; the mouse pointer moves, but the interface is completely unresponsive to mouse clicks.
I then decided to install 11.04 64bit since I will be upgrading the RAM soon. This install also went fine and soon had my system up and running. Unity still crashed frequently, so I switched to classic mode. However, this time I chose classic mode without effects. I have not experienced any crashing or locking up in the three days since I made this change.
I would recommend that you try installing Natty again, but try running it in classic mode without effects until some of these bugs get worked out. I also recommend adding information to the bugs that have been already filed on Launchpad and also open new bug reports for problems that have not already been reported.
I had the same or at least a similar issue with natty 64bit installed on a thinkpad L520 (sandy bridge, too). It didn't boot and showed only flickering green lines. Well, I found a solution by looking at the Grub2 documentation on a German Ubuntu site. There I stumbled over the following sentence: "if there are boot problems with the default grub2 settings (black or distorted screen), then you should choose the following setting. With this setting a list of problematic graphic cards ("blacklist") is processed during boot." (rough translation) So I added the following line in /etc/default/grub (open the file with sudo or gksudo):
GRUB_GFXPAYLOAD_LINUX=text
saved it and ran:
sudo update-grub
Now booting just runs fine.
Best wishes, absurd
absurd
