50
I want to have both KDE and Gnome shells on Ubuntu. Ubuntu only has Gnome installed by default. How do I install KDE?
David
  • 3,487
User
  • 4,566
7 Answers7
49
You need to install the kubuntu-desktop package for the full install with the following command.
sudo apt-get install kubuntu-desktop
Then the next time you login you can choose what to use from the login screen (under Session).
karel
  • 122,292
  • 133
  • 301
  • 332
Hamish Downer
  • 19,506
10
To get just the plasma environment (on 12.04 and newer):
sudo apt-get install plasma-desktop
It worked fine for me on 15.10
If you want to log in from KDE run sudo apt-get install kdm, sudu apt-get remove gdm, and dpkg reconfigure kdm.
rjh
  • 167
Just try the following command in a terminal
Then just select KDE on the login manager.
jokerdino
  • 41,732
LnxSlck
  • 12,456
On 30/09/2015:
To install KDE on Ubuntu (12.04,14.04,14.10,15.04,15.10) (plasma 5.3)
sudo add-apt-repository ppa:kubuntu-ppa/backports
sudo apt-get update && sudo apt-get dist-upgrade
To install KDE on Ubuntu (15.04,15.10) (plasma 5.4)
sudo add-apt-repository ppa:kubuntu-ci/stable
Note: To install plasma 5.4,you need to remove backports ppa.
launchpad.net/backports
launchpad.net/~kubuntu-ci/stable
Ravan
  • 9,567
Just open synaptic (If not installed yet, install it by ubuntu software center) and search for desktop environment and install plasma-desktop
Prasad RD
  • 2,043
I think the most complete answer is here. According to what you want to install (only the GUI or GUI+some packages).
Citing the content of the answer:
plasma-netbook and plasma-desktop differ only by whether they install the netbook or the desktop interface. kde-workspace is identical to plasma-desktop.
kde-plasma-desktop will install a few KDE programs: Dolphin, Konqueror, kde-baseapps, konsole, kwrite, and kde-passwd.
kde-standard installs a bunch of stuff on top of kde-desktop: Akregator, Ark, Dragonplayer, gnupg, Kaddressbook, Kate, KDE wallpapers, Kmail, etc.
kubuntu-desktop installs even more than kde-standard. kubuntu-desktop is the package you would download from the Ubuntu website if you wanted Kubuntu, but if you only want the Plasma interface, not any of the default programs, plasma-desktop might be sufficient.
Choose the package you want and then run sudo apt-get install package-name
