I tried to install Ubuntu on a machine having Windows OS.While installing Ubuntu I was not able to see all the partitions and I had to format the hard drive. Now the result is that I am having the clean Hard Drive with no primary partition and I am not able to install Windows OS also.
Please suggest me some steps to how can I install Windows OS and Ubuntu on the same machine?Also suggest me steps to create primary partition.
I googled but while following the steps got messed up.Please suggest me some links.
JoKeR
  • 7,062
Fix boot After installing ubuntu the default boot will be GRUB so you need to replace it with MBR and below is how to fix it
1- boot from windows 7 or XP CD. 2- select repair --> cmd prompt. 3- input bootRec.exe /fixmbr
then you can install windows without any problem
Dual boot windows and ubuntu
please check the below URL
UBUNTU Wubi installation
