Today, I installed a fresh Ubuntu 12.04 LTS on my Sony VAIO VPCSB.
I noticed a high cpu use of init and yes (as you can see below).
top - 16:26:16 up 11 min, 2 users, load average: 2.71, 2.86, 1.82
Tasks: 183 total, 7 running, 176 sleeping, 0 stopped, 0 zombie
Cpu(s): 5.1%us, 33.4%sy, 0.0%ni, 61.1%id, 0.3%wa, 0.0%hi, 0.1%si, 0.0%st
Mem: 3962180k total, 1771012k used, 2191168k free, 47420k buffers
Swap: 4107260k total, 0k used, 4107260k free, 1028536k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1 root 20 0 24604 2528 1352 R 58 0.1 6:15.32 init
1197 root 20 0 4316 348 272 R 49 0.0 5:20.69 yes
60 root 20 0 0 0 0 S 22 0.0 1:24.63 kworker/2:1
2429 root 20 0 0 0 0 R 15 0.0 1:15.54 kworker/0:0
39 root 20 0 0 0 0 R 9 0.0 1:18.98 kworker/1:1
1845 root 20 0 0 0 0 S 6 0.0 0:40.58 kworker/3:2
1162 root 20 0 339m 106m 81m R 2 2.8 0:29.62 Xorg
1962 ingo 20 0 1116m 103m 59m S 2 2.7 0:11.16 compiz
1995 ingo 20 0 495m 16m 11m S 1 0.4 0:00.18 nm-applet
Is there a solution?
Greetings
Edit: I took a closer look at the kworker
I found this Why does kworker cpu usage get so high?
$ grep . -r /sys/firmware/acpi/interrupts/
/sys/firmware/acpi/interrupts/sci: 729
/sys/firmware/acpi/interrupts/error: 0
/sys/firmware/acpi/interrupts/gpe0A: 0 invalid
/sys/firmware/acpi/interrupts/gpe17: 729 enabled
/sys/firmware/acpi/interrupts/sci_not: 0
/sys/firmware/acpi/interrupts/ff_pmtimer: 0 invalid
/sys/firmware/acpi/interrupts/ff_rt_clk: 0 disabled
/sys/firmware/acpi/interrupts/gpe_all: 729
/sys/firmware/acpi/interrupts/ff_gbl_lock: 0 disabled
/sys/firmware/acpi/interrupts/ff_pwr_btn: 0 invalid
/sys/firmware/acpi/interrupts/ff_slp_btn: 0 invalid
I am not sure if it is the kworker bug, still missing is the starting point of yes. Any suggestions how I could find it?
Now i tried to set up Ubuntu 12.04 fresh, and got a error message on the first start
package: fglrx-pxpress0.6~hybrid0.0.1
I really have no idea how to fix this, and excuse me, if i am missing something important here, just started with Ubuntu.
Picture from System Monitor with Yes process
$ lsof -p 1182
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
yes 1182 root cwd unknown /proc/1182/cwd (readlink: Permission denied)
yes 1182 root rtd unknown /proc/1182/root (readlink: Permission denied)
yes 1182 root txt unknown /proc/1182/exe (readlink: Permission denied)
yes 1182 root NOFD /proc/1182/fd (opendir: Permission denied)
The try out Ubuntu works fine, I have no clue how to fix this.
And it isn't possible to end/kill the yes process with the system monitor.
sudo lsof -p 1182
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/ingo/.gvfs
Output information may be incomplete.
yes 1182 root cwd DIR 8,1 4096 2 /
yes 1182 root rtd DIR 8,1 4096 2 /
yes 1182 root txt REG 8,1 22912 2622732 /usr/bin/yes
yes 1182 root mem REG 8,1 1815224 17301515 /lib/x86_64-linux-gnu/libc-2.15.so
yes 1182 root mem REG 8,1 149280 17301627 /lib/x86_64-linux-gnu/ld-2.15.so
yes 1182 root 0u CHR 1,3 0t0 1029 /dev/null
yes 1182 root 1u CHR 136,19 0t0 22 /dev/pts/19
yes 1182 root 2u CHR 136,19 0t0 22 /dev/pts/19
